Offroad & 4x4
shackle flip ?'s
Old Feb 5, 2011 | 02:24 AM
BeastF-250's Avatar
BeastF-250
shackle flip ?'s
i have an 84 f250 and looking to do an shackle flip. would i be able to just to grind the rivits off and change the passenger side to the drivers and vise versa and drill holes in the frame and bolt it up or is it harder then that?
Old Feb 5, 2011 | 08:54 AM
Bender99's Avatar
Bender99
You can but you'll only gain about 2 inches of lift that way. You can take a set of hangers for the front of the rear leafs and hang the shackle sown for more lift pretty cheap.
Old Feb 5, 2011 | 11:49 AM
joe f350's Avatar
joe f350
this i what u want
Ford Rear Shackle Flip Kit - Sky's Off-road Design
Old Feb 5, 2011 | 12:14 PM
fatdan460's Avatar
fatdan460
like joe said, if you want a little more lift than the homebrew setup will get you there are aftermarket options. they are all in the 4-5'' range depending on mounting location. this place also sells a stout kit:Universal Shackle Flip Kit [FORDFLIP] - $195.00 and so does this guy, but he hasn't listed them on the site yet, but they look like the route i'll end up going because his are cheaper, and they look pretty damn good to me. e-mail the guy if you are interested in his. he does great fab work, but he's not really good on updating his site: HeftyFabWorks - Custom bumpers, rock sliders and more for your truck or vehicle
Old Feb 5, 2011 | 09:58 PM
tecgod13's Avatar
tecgod13
Unless I'm mistaken, passenger and drivers side are the same, so switching them won't do anything for you.
Old Feb 5, 2011 | 10:43 PM
fatdan460's Avatar
fatdan460
See, not so much fail in this one. you are in fact correct, they are the same.
Old Feb 7, 2011 | 02:22 PM
BeastF-250's Avatar
BeastF-250
so if i take the stock ones and flip them will they hold up being they were made for the other direction?
Old Feb 7, 2011 | 05:08 PM
alpha/omega's Avatar
alpha/omega
Originally Posted by joe f350
No, this is what you want.
Use PBB10 in the offer code section for 10% off.
Old Feb 7, 2011 | 05:16 PM
fatdan460's Avatar
fatdan460
R
i posted ruffstuff. even with the 10% off i'm still going with hefty fab as they are cheaper and they look good to me.
Originally Posted by Hefty
3/8" mounting plate. 1/4" spring mount and gussets. All CNC cut for accurate fitment.
(come fully welded. sorry just tacked in the picture)
Price $145 per set
I believe he changed the design a bit from these photos.
Old Feb 7, 2011 | 05:24 PM
alpha/omega
Heftys dont come with shackles iirc and are not drilled to use the factory holes without having to adjust them for shackle angle.
Old Feb 7, 2011 | 05:25 PM
fatdan460's Avatar
fatdan460
i was just about to post that i overlooked the shackle part. he wants another 145 for those, so it looks like ruffstuff it will be.
Old Feb 7, 2011 | 05:29 PM
Redneck1465's Avatar
Redneck1465
Are you looking to do the front shackle reversal or the rear shackle flip?
Old Feb 7, 2011 | 05:37 PM
alpha/omega
Im going to go with a mid-shackle as a catch all.
Old Feb 7, 2011 | 05:45 PM
fatdan460's Avatar
fatdan460
i heard mid shackles are the hot new thing for jeeps. google it.
Old Feb 7, 2011 | 05:50 PM
joe f350's Avatar
joe f350
i like skys 169 buck and there a good product
