Rocker arm assembly
Old Feb 4, 2011 | 07:36 PM
rdweathers's Avatar
rdweathers
Rocker arm assembly
Would putting the rocker arm assembly from a 74 390 in the cleaning tank be ok? Was not planning to disassembe the rocker arm assembly. Having seconds thoughts and may just put it back as is.
Old Feb 4, 2011 | 07:39 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If you pop the end the plugs you can really clean it out. But I wouldn't submerge the whole assembly without removing the end plugs.
Josh
Old Feb 4, 2011 | 07:42 PM
rdweathers's Avatar
rdweathers
Are the end plugs reusable or do you replace them?
Old Feb 4, 2011 | 07:47 PM
Bullitt390's Avatar
Bullitt390
If you're carefull they can be, but NAPA and many others will have some in stock.
Josh
Old Feb 5, 2011 | 05:21 PM
rdweathers's Avatar
rdweathers
I went ahead and disaasembled one of two rocker arm assemblies to clean them up correctl. I numbered the rocker arms so i could put them back exactly how i disassembled them although my numbering did not hold up. Does it matter which rocker arm goes where on the shaft. I know to have the oil holes in the shaft pointing toward the head and the smaller shank bolt in the oil boss of head. I kept track of where the push rods go. I am going back with new lifters and a new cam. Thank you.
Old Feb 5, 2011 | 06:03 PM
Bullitt390's Avatar
Bullitt390
It's a good idea to keep things in order, but there is no need. Don't lose sleep over it.
Just make sure the oil holes, as you said, point down and the special bolt goes to the oil feed.
Josh
flamesoldier
Jan 10, 2013 04:01 PM
FSeybert
Dec 10, 2011 10:27 PM
1975Ford
Sep 25, 2006 08:44 AM
2speed
Apr 2, 2004 03:42 PM
biederboat
Aerostar
Jul 16, 2002 04:55 PM
