FTE How To: Billiard Ball Shift Knobs
Old Feb 7, 2011 | 09:53 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by Maverick1978
well yeah i guess so. and not cracking the ball when you started drilling it. what are them things made out of anyways?
Billiard ***** are made of a high density plastic resin. It's easy to drill and easy as pie on a drill press... mine has a hole on the platform and the ball doesn't roll around. A firm grip is all you need.
In hindsight, I should have drilled the hole slightly off-center to the right side because the shift lever is angled and the number is always facing me. Whereas I think it would have looked better at mostly a vertical orientation. Oh well, there are more billiard ***** to be had!
Old Feb 10, 2011 | 10:56 AM
Maverick1978's Avatar
Maverick1978
ohh okay. thanks for tellin me. yeah i drilled mine directly on the number of the opposite side. sooo i hope it works. i had to drill mine 11/32's inch wide and took the ball to my ag shop and tapped it 3/8 inches
Old Feb 10, 2011 | 03:28 PM
HIO Silver's Avatar
HIO Silver
Maverick, Post a pic when it's installed!
Thanks!
~Goose
Old Feb 10, 2011 | 04:21 PM
Maverick1978
ok. ill be sure to do it only one i could find was an old 12. i think i mighta messed up the threads but i'll git-r-done
Old Feb 10, 2011 | 05:55 PM
jjsfrd's Avatar
jjsfrd
Originally Posted by 78 PEB
Not to sound rude, but why do you think the original **** had a nut under it?????????LOL
Mine does.
J
Old Feb 10, 2011 | 07:09 PM
Maverick1978
so does mine lol they needed em on the dentside's door locks. those plastic ***** that went over the screw would crack if you put them in too far
Old Feb 11, 2011 | 09:38 AM
HIO Silver's Avatar
HIO Silver
It's a jamb nut used to compress against the shiftknob to maintains is orientation.
Old Feb 11, 2011 | 01:21 PM
ChaseTruck754's Avatar
ChaseTruck754
That was his point...
Old Feb 11, 2011 | 01:26 PM
78 PEB's Avatar
78 PEB
I guess nobody got my sarcasm............
Old Feb 11, 2011 | 01:27 PM
ChaseTruck754
I did.
(text for stupid 10 character rule)
Old Feb 11, 2011 | 02:06 PM
78 PEB's Avatar
78 PEB
And I appreciate that fact........LOL
Old Feb 11, 2011 | 03:31 PM
HIO Silver's Avatar
HIO Silver
I did get it.. I just didn't wanna be an a-hole about it so a factual answer seemed the safest cuz sarcasm doesn't translate well in text.
Old Feb 11, 2011 | 09:00 PM
  #28
EWHOLTZCLAW's Avatar
EWHOLTZCLAW
So just to be sure. For your application you used 11/32 drill bit and then just tapped the ball itself and did not use any kind of insert? and then tapped the ball to 3/8?
Old Feb 11, 2011 | 10:54 PM
  #29
montana_highboy's Avatar
montana_highboy
Looks ridiculous IMO but to each their own, i prefer the original *****.
Old Feb 12, 2011 | 08:32 PM
  #30
Maverick1978
yepp. thats exactly how i did mine. but you gotta be very careful to not strip the inside of the ball out. i almost did. I used the coarse thread tap for mine. I'm not sure if your susposed to use coarse or fine threads.
