machine shop screw up
Old Feb 4, 2011 | 03:27 PM
ekm71f100's Avatar
ekm71f100
Thumbs down machine shop screw up
ok well i guess its time for a new macine shop, he's messed up with my motor 4 times so far,
1. He messed up while boreing out my motor, and he had to get a whole new block, took him 6 weeks just to get my motor back to me.
2. he lost my rockers
3. when i gave him my heads he told me they were gonna cost about 200 to rebuild, i got the bill back and the heads to rebuild were 540$$, WTF!
4. when i got my heads back this morning i got them torqued down on my block and started putting it back togethr. i put in my new lifters, i put in the push rods and when i put my rockers on they didnt even touch the pushrods. the rocker bottoms out on the stud shoulder, i took a pushrod out and compared it to the ones i took out, they are the same length, i pulled a lifter out and it was the same as the old one,
i called the machine shop and he assured me that he did everything right, and hung up really fast,
so heres my question, it seems to me like the new valves he put in are shorter? or the studs that he put in are too long, could i fix it by putting in longer pushrods or what shoud i do?
Old Feb 4, 2011 | 04:17 PM
Mike G's Avatar
Mike G
What motor is this he is working on. Take the heads back and ask him to pull a comparable set and see whats wrong. If he bows out, I would suggest that you mention to him he should put it together since he believes he did everything right and charged you extra...
Old Feb 4, 2011 | 04:34 PM
ekm71f100's Avatar
ekm71f100
hes rebuilding a 302 that going in my 67 stang, i called him and told him that there was a problem and he said he did it right nd hung up on me, so him hanging up, to me sounds like he knows he did something wrong, i really dont want to pull the heads back off bc theyre already bolted down and the headgaskets im using arent cheap. thats why im wandering if longer pshrods will solve the problem
Old Feb 4, 2011 | 05:27 PM
jowilker's Avatar
jowilker
You do have a right to recoop your loss. I suggest you contact an attorney, it will probably get complicated before it's resolved.
John
Old Feb 5, 2011 | 06:06 AM
Talltruck's Avatar
Talltruck
Dumb question here, are you sure if the replacement block isn't a 351? The blocks are very similar but a 351 has a taller deck height that would make the 302 pushrods be too short???
You can tell quick and simple, if the water pump bosses are right at the level the heads are at then it's a 302, if there's about a 1/2" gap then it's a 351.
Old Feb 5, 2011 | 09:31 AM
TigerDan's Avatar
TigerDan
Or see if you intake manifold will sit right in place or if there's a huge gap between the manifold and the heads...
Valve geometry is critical, simply installing longer pushrods can throw things off. When the valve opens,and closes the rocker basically rubs across the end of the valve stem, If the pushrods are too long, the rocker can actually come off the valve stem.
Are the lifters correct? Do you have a new cam, possibly one that's been reground and has a smaller base circle?
Old Feb 5, 2011 | 11:47 AM
Victor L's Avatar
Victor L
First off, I would try just being cool with the machinist. Go to his shop when you know the timing is right, and ask his advice. At this point the most economical solution may be to install a custom length, or correct set of push rods.
An attorney would not be an economical solution, probably at least $600.oo.
Old Feb 5, 2011 | 11:57 AM
Kalve's Avatar
Kalve
compare blocks an see if that is the correct block he gave you an then see what he says when you stop by. then contact the better business if it is still not resolved an take it from there.
Old Feb 5, 2011 | 07:51 PM
Ford_Six's Avatar
Ford_Six
Quick way to tell 302 from 351 is the block behind the distributor, just below the intake- The 302 is about flush, the 351 has about a 1" step. If it is a 302 rotating assembly in a 351 block, then the pistons would be quite a bit too low in the block to even run as well.
Old Feb 5, 2011 | 10:26 PM
TigerDan's Avatar
TigerDan
Wouldn't even fit...the 351W has larger main bearing journals than a 302, even an idiot of a machinist would know something wasn't quite right if he tried to put a 302 reciprocating assembly into a 351W block as soon as he set the crank into place...
Old Feb 7, 2011 | 11:12 AM
bmuhlbach's Avatar
bmuhlbach
also the oil pans aren't interchangeable between a 351 and a 302.What year is the block and the heads?I think rooler cam push rods are shorter then non rollers.In 1970 they went to the torque down lifters before 1970 are like Chevys where you have to adjust them with the engine running.
Old Feb 7, 2011 | 12:24 PM
pit_of_pity's Avatar
pit_of_pity
If you paid with a credit card, contest the charges with the credit company. It might take 6 months or more, but worth a try. Prepare all the paperwork that sways in your favor (photographs, invoices, etc). And stay away from ****ty mechanics.
Old Feb 17, 2011 | 12:13 AM
ekm71f100's Avatar
ekm71f100
well he finally decided to answer my calls after i left a voicemail saying something about an attorney, lol. he came and picked them up, and decided to fix it, he wouldnt tell me straight up what he did but it looks like the studs that the rockers sat on were changed, when he brought them back he was about to leave and handed me 500$ cash, "i hope we can still do buisness later on, and again im very sorry" were his exact words, guess i did alright getting both heads totally rebuilt for $40, haha
Old Feb 17, 2011 | 03:45 AM
jowilker's Avatar
jowilker
Businesses can make mistakes, can break things etc., but our laws make them liable when they damage or break something.
John
Capt'n Phillips
Washington Chapter
15
Nov 15, 2013 12:23 PM
jtindale
Jul 20, 2012 10:45 AM
jeffmeyers351
Jun 11, 2012 07:17 PM
lukecline
57
Jun 23, 2006 11:49 PM
TOUGHY17
Nov 6, 2001 10:27 PM
