Overheating ? Maybe.
Old Feb 5, 2011 | 07:07 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I've heard that blowing head gaskets on 6.9's aren't to uncommon. 6.9's have smaller head bolts, and it may happen while working it hard (like this thing always does) the head can slightly lift off the head, and blowing the gasket.
If I known this before doing the gaskets I would of studed the heads, even though i'm not planing on a turbo, it's still cheap insurance to make sure I never have to go through that again.
Old Feb 7, 2011 | 04:03 PM
Fordranchero's Avatar
Fordranchero
Well, I'm sure that you are correct about the sending unit because when I went out this morning the temp light came on and stayed on the minute I turned the key.
Now I just need to get the gauges installed. Found a brand new 3 gauge cluster still in the box in my shop.
Old Feb 7, 2011 | 04:28 PM
IDIDieselJohn
Oh yes, it's still suppose to light up when you crank it, as a test to show the operator the light still works.
But it will no longer light up if there's actually a problem.
Or is yours stuck on?
Cause that's exactly how mine is setup, using the temp light switch. I've been told you can use either port, but I still wanted my dash gauge to work, so I had to use the light switch.
Old Feb 7, 2011 | 04:40 PM
Fordranchero
No, it's stuck on now.
Old Feb 7, 2011 | 04:47 PM
IDIDieselJohn
Hmmmm, I don't remember having that happen to me.
If the camper was here right now I'd go out to it to see exactly what I did, I'm pretty sure I just connected it to the port sensor. Cause I'm trying to think maybe of a T on it to make both gauge and light functional, but I don't at all remember doing that.
Old Feb 7, 2011 | 07:22 PM
Fordranchero
I'm just going to pull the light sensor and put the thermocouple in, forget about the light and run both the dash gauge and the real gauge.
Also going to put in a real oil pressure gauge, already have amp and voltage cause this used to be an ambulance so they had it decked out to monitor power.
Charges batteries fast with a 165 amp alternator.
Might take a shot at moving the wait to start light as well, its in a stupid spot.
kr98664
Jun 22, 2017 11:06 AM
Antiquer88
Sep 1, 2016 10:23 PM
NorthlandBass
Aug 9, 2016 02:13 PM
Raise
47
May 13, 2015 08:22 PM
Raise
May 11, 2015 08:55 PM
