REVERSE ACCELERATION?????
Old Feb 3, 2011 | 08:50 PM
B1GKAHUNA's Avatar
B1GKAHUNA
Started truck, foot on the brake, put in reverse, as I was letting off brake and starting to move in reverse, it reved-up an accelerated. Its done it twice in two days now. Whats the deal???
Old Feb 3, 2011 | 10:05 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
That's not a lot of info to go on, but on '03/early '04's failed ICP sensors are fairly common and can cause a surge like that. There's a good write up on it in the tech folder sticky at the top of the page.
Old Feb 3, 2011 | 10:39 PM
B1GKAHUNA's Avatar
B1GKAHUNA
thanks, i just bought a icp that im changing this weekend due to oil leak suspect. would this also cause some irradic turbo opening/closing-at least thats what it sounds like at the exhaust when at start-up?
Old Feb 4, 2011 | 07:51 AM
lawnboy1965's Avatar
lawnboy1965
If you have the newest flash the turbo and EGR sweep are part of it.
Old Feb 4, 2011 | 10:06 AM
6point0's Avatar
6point0
what exactly do you mean by " sweep"?
Old Feb 4, 2011 | 10:20 AM
npccpartsman's Avatar
npccpartsman
If you're familiar with the workings of a VGT turbo, sweep would mean that the turbo vanes get moved through their operating range to prevent carbon buildup from freezing them in one position. Sweep could also be read cycle. I've never heard that the EGR valve went through the same cycling sequence though.
Iron Port
1978 - 1996 Big Bronco
Jun 26, 2017 03:35 AM
00SuperDuty7.3
Feb 22, 2017 04:48 PM
sprad1970
Feb 21, 2017 03:07 PM
Nigma
Sep 21, 2016 02:38 PM
atharp
Sep 24, 2004 01:53 AM
