460 or 300?
I've got a 69 F250/360/C6/2WD. The 360 is a commercial rebuild (Jasper or such) of a cool service block that the numbers say is one of the best of the best, high nickel content, can be bored/stroked to anything from 352 thru 428, etc. It just started exhibiting a possible/slight knock (sounds like maybe classic wrist pin or cracked piston skirt) at about 80-85 mph on the highway and I've kinda been looking for an excuse to pull it and make it a 390 or 410
but just couldn't justify pulling apart a good running, non-leaking, non-oil burning engine. The real problem around here is that it is not unusual to have to cruise at 70-85 mph to avoid being a road hazard and without any overdrive (even though I run tall 285/75/R16 tires) the engine is "SCCRRREAMIN'" at that speed. I'm pretty sure the engine won't give the ghost anytime soon, and it's not my only driver, so I have time to plan and scheme.
If I turn the engine into 390 or 410 it will likely be for a car, (maybe my 68 Mustang) as there is no good trans option, except maybe a Clark, without adaptors, manual or auto for an FE in a truck. So.... I'm looking at what options there are for other engine/trans combos to still have a TRUCK that can pull when I'm done and still be able to keep up on the highway. I'm not necessarily stuck on manual or automatic for the transmission and certainly am aware of the cool factors of a good inline 6 cyl, as well as the gas gulping properties of a 460.
I just need to know what stout overdrive transmissions will fit behind the various engine/bell housing pattern families, IE:>300-6 cyl/302-351-Windsor-I think they're the same?
>FE-I realize not much
>385 series-370-429-460
All Thoughts and wisdom are welcomed.
Thanks,
Gene
Another combo I personally want is a 300 / ZF with 3.55's.
Ful mileage is going to suck no matter what you do. You can make it suck a little less with higher gear ratios.
I love the 300, but that's just me. I'm not about to compare the 300 and the 460. The 300 is a great truck engine but the 460 has it on sheer size.
They're both great truck engines.
You are used to the power so a mid/late 80s early 90s 460/AOD might be the ticket.
John
Quick Time has a pretty nice selection of bellhousings that will let you put just about anything you want as far as a manual trans behind the FE; an option if you want to go there.
You can go much lower with the rear gearing too; down into the 2s but at that level the towing capabilities aren't too good and you'd really want an automatic setup because it would fry a clutch.
Big up front little in the rear. Got to have the balance.
John
I currently have a Gear Vendors unit which I picked up used behind a T19 in my truck, and it really makes a difference in cruise RPMs. With 3.73s my truck is quite happy to cruise at 70-80. Next I'll be going to 3.54s.
