B&M Transpack
Old Mar 10, 2003 | 10:26 AM
ACRKENTUCKY's Avatar
ACRKENTUCKY
B&M Transpack
Does anyone recommend or have experience with a B&M transpack? I was thinking about purchasing one, I just wanted to hear some input before i did. Thanks
Old Mar 10, 2003 | 05:03 PM
Loopie's Avatar
Loopie
B&M Transpack
Not sure if this will apply.....but I bought a B&M kit(the mild one) for my '87 Mustang AOD....the tranny shop advised against it. He said they shift too hard for a stock tranny and will cause problems within a yr.(he had some previous experiences)
There was a milder yet shift kit available that he found to be OK in stock AOD's.....MAYBE a Trans-go??? I can't recall exactly.
Old Mar 10, 2003 | 05:22 PM
ACRKENTUCKY
B&M Transpack
Yea ive heard of that, well if thats what you heard than maybe i outta look into the transgo kits, thanks buddy.
Old Mar 10, 2003 | 05:39 PM
Hit Man X's Avatar
Hit Man X
B&M Transpack
I HIGHLY recommend a TransGo kit. The PSK-AOD. It is a great kit and rids the trans of inherent problems. Also, it is adjustable for different shift firmness by the spring installing. It will also raise you WOT to 4900 or 5200 with the governer install.
It tells you not to put both in for softer shifts and more for firmer shifts.
Also, get an aluminum 2-3 accumulator, a "A" OD servo and spring. Those will help in holding for towing and such.
Reply and I'll post up the Ford part numbers for those parts.
410 Highboy
Apr 17, 2009 08:03 PM
ACRKENTUCKY
Mar 8, 2003 10:18 AM
xuare
Nov 14, 2002 12:06 AM
Petrol
Jul 9, 2002 09:08 AM
79F2504x4
18
Mar 13, 2002 10:45 AM
