lockers for rear diff.
Old Feb 2, 2011 | 11:36 AM
lonewolf777's Avatar
lonewolf777
Would it be worth it? I don't go off road just want a little more traction in the snow.My ranger is a 4x4 also
Old Feb 2, 2011 | 12:44 PM
grandmas77f150's Avatar
grandmas77f150
Do you already have limited slip? If so, don't get a locker, you won't get much benefit unless you wheel a lot.
Old Feb 2, 2011 | 01:29 PM
lonewolf777
I dont know! - 4.10 gears 8.8
Old Feb 4, 2011 | 03:48 AM
02FX45.4's Avatar
02FX45.4
There should be a metal tag on one of the bolts that holds the differential cover on. There will be a series of numbers then someting like 4 10 88 if it says that then you have an open (nonlocked) rear carrier. If it says 4L10 88 then you have a limited slip carrier wether it be a clutch pack or torsion. There should also be a axle code on the driverside door pillar of the truck. That will be good unless your truck has had a gear swap. What year is your truck btw?
Old Feb 4, 2011 | 11:41 AM
lonewolf777
when I changed the oil I took the tag off! but what you told me it's not a limited slip .It started off with 4.10 88 then 33 vol
Old Feb 4, 2011 | 12:24 PM
lonewolf777
when I changed the oil I took the tag off! but what you told me it's not a limited slip . 4 10 88 3d04 v33ol
Old Feb 4, 2011 | 04:45 PM
Level2's Avatar
Level2
I wouldn't run a locker. A good LS differential is all you need. Torsen/ Detroit Locker/ Eaton and many others make a perfectly good LS diff. I hear the Detroit Tru-Track is really good.
Old Feb 5, 2011 | 01:31 PM
lonewolf777
the reviews I read on the detroit tru track are good so, I'l look into that more - thanks for the replys.
Old Feb 9, 2011 | 09:59 PM
Taumac's Avatar
Taumac
You can also pull a limited slip from a explorer Ive been told by another website. Thinking of it myself. Ive read that a explorer came with 31 spline axles, disc brakes and a limited slip and will bolt right in place btw get the master cyclinder for a explorer.
Old Feb 9, 2011 | 10:09 PM
grandmas77f150
Disc brakes from an explorer are not bolt on.
Old Feb 9, 2011 | 10:23 PM
Taumac's Avatar
Taumac
Im sorry you have a 4x4 shouldnt you have a limited slip already? No I was talking about totally swapping out rear axle out for the Explorer one. Thats was my plan.
Old Feb 10, 2011 | 09:58 AM
Level2's Avatar
Level2
Ls is not a standard option even with 4x4 depending on the year.
Old Feb 10, 2011 | 04:26 PM
smalltrucker's Avatar
smalltrucker
No way is the Explorer just a "bolt-in". Explorers mount the springs underneath while the Rangers mount on top. Have to move the perches, reset the pinion angle, get new shock brackets. My 2000 4x4 had an open rear end but I installed a Richmond "No-Slip" for Winter traction. Liked it so much bought one for the 4x2.
Dave
Old Mar 30, 2011 | 11:53 AM
02FX45.4's Avatar
02FX45.4
There is also a difference between the explorer and the ranger rear ends that nobody has mentioned. The explorers are a 31 spline axle and the rangers are a 28 spline. There is no swapping out the center section between these rear ends and expecting your current axles to be used. Unless you have new axles made. Now the FX4 level 2's have the correct spring pad placement and are also 31 spline and most were 4.10 gears. There is also no difference in the master cylinder either.
Old Mar 30, 2011 | 08:51 PM
Level2's Avatar
Level2
All the Level II trucks came with a 4.10 Torsen helical LS 31 spline rear axle.
yellodog
Apr 11, 2016 08:26 AM
ryan peterson
Jul 13, 2015 01:51 PM
Schickel
Mar 13, 2014 09:25 PM
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
GregR
May 9, 2000 07:41 PM
