Can you guys tell me what the difference is between the two below and which would be better for my 66? I've never messed with these before and only removed my old one but want new parts on the 460.
I don't understand the Notes part that says one is 10.00 LBS and the other says works with Internal or External Balance. If I did not take my timing chain off, do I have to do anything to it? Also, does the outside diameter matter?
Id find out first what year the engine block is. Since its not original to the truck, god only knows where its from. Get the ford part numbers off of it (balancer), so you can more or less get an idea of where its from. try a quick google search of the number.
