Lights fluctuating after start up?!
Old Feb 2, 2011 | 09:03 AM
snaponprofile's Avatar
snaponprofile
Exclamation Lights fluctuating after start up?!
Hey guys, I got something going on electrical wise. When I started up my truck a couple weeks ago I noticed that right after the truck started, the batt. gauge fluctuated from 8 to 14 and back and forth for about 20 seconds. First I thought, stupid stock gauge, then I turned my lights on and they were fluctuating too. Very dim, then normal, then very dim again then normal again and so on up until about 20 seconds then it stops and everything works perfectly. Engine does this every time I start now. My batteries are 1 year old and spin the engine fast so that out of the question. I though of a loose connection but it stop after 20 seconds and doesn't flicker or anything while driving. Thoughts??
Old Feb 2, 2011 | 09:11 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
how long have you driven a diesel?
thats normal.that's the afterglow cycling the glow plugs a bit to keep your engine running good while it first starts.since they draw so much power,you'll see the volts fluctuate and the lights dim and brighten if they're on, until the cycle is complete.
Old Feb 2, 2011 | 09:20 AM
snaponprofile
Oh wow do I feel stupid, 2 years and I just never noticed it before. I pay closer attention to the gauges ever since I pulled everything apart for the turbo install. I guess every little thing make me uneasy, I was convinced I had never seen it do that before though. I have a vibration in my dash that annoys the mess outta me when driving ever since the turbo too. I'm not sure if its because the timing is off or the turbo added more vibration or a combo of both anyways. I've tried to find it more than once and I think its right behind the radio, so annoying. Anyway, kind of a rant there, thanks.
Old Feb 2, 2011 | 09:30 AM
87crewdually's Avatar
87crewdually
Vibration. You may not of clearenced the firewall enough for the up-manifold or down-pipe. That's where I'd check.
Old Feb 2, 2011 | 09:37 AM
snaponprofile
Yep, checked there. Heat shield on turbo is clearing, down-pipe and up-pipe are too (I think, I'll have to double check). The vibration sounds like plastic vibration in the dash, not really metal on metal. But I guess if the down-pipe and up-pipe were vibrating through the whole firewall, it would cause the dash to vibrate too. It only vibrates upon acceleration and deceleration and at idle a tiny little bit.
Old Feb 2, 2011 | 09:42 AM
87crewdually
Some silicone spray can help with dash squeaks of plastic on plastic joints.
Old Feb 2, 2011 | 09:44 AM
snaponprofile
What like this stuff. It seems like it would help, I guess I could spray some under the dash.
Old Feb 2, 2011 | 09:49 AM
87crewdually
Yup. There's all brands available. Whereever two dash panels come together you can open the gap alitlle and spray some in to coat the surfaces. Also if you have slow or dragging power windows, using the spray straw on the can nozzle, spray it in the window tracks and work the window up and down. You'll be amazed.
Old Feb 2, 2011 | 09:54 AM
snaponprofile
Alright, some of that on order, thanks. Although I replaced both my power window regulators recently, thats good to know for the other cars.
Old Feb 2, 2011 | 10:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle
My bet is the down pipe making contact with the body when you have torque on the engine.
Sounds like a funny hum/buzz, not like metal to metal clang type noise.
Old Feb 3, 2011 | 11:10 AM
snaponprofile
Yep pretty much sounds like plastic buzzing - really annoying especially when I can't find it. I'm gonna check the down pipe clearance today as well as try to get my temp gauge working.
Old Feb 3, 2011 | 02:44 PM
snaponprofile
Hey guys got the rattle figured out. Th DP clamp was rubbing on the floor pan heat shield rotated clamp and no rattle - thanks guys. FTE rocks.
dubcnea
Dec 6, 2013 11:07 AM
w_huisman
Nov 8, 2013 06:00 PM
pomial
Oct 20, 2013 12:00 PM
facial
1997 - 2003 F150
Nov 27, 2008 07:43 AM
molybdenum26
1997 - 2003 F150
Nov 23, 2004 08:39 AM
