electric fuel pump conversion question
Old Aug 24, 2014 | 01:44 PM
1979 300i6's Avatar
1979 300i6
I've got my pump wired in with a oil pressure shut of switch and relay. My issue is with the "I" terminal on the switch says it needs to go to a ignition source so I wired it into my ignition modules red wire and the pump works fine and everything works fine but I have recently read that this may hurt the truck and that my ignition source should actually be wired into the ignition switch so now My question is where does my wire go on the ignition switch at?
Old Aug 25, 2014 | 12:08 AM
Jdeshler's Avatar
Jdeshler
The only way I see this hurting your ignition system is by overloading it.. you should consider wiring in a 5 wire relay so the ignition voltage is used to switch the relay on so it flows a better more direct current from the battery.
Old Aug 25, 2014 | 12:31 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Read this thread by fmc400, this is the way to hook up an electric fuel pump.
https://www.ford-trucks.com/forums/1...sion-pics.html
Old Aug 25, 2014 | 06:54 AM
Jdeshler's Avatar
Jdeshler
I read that last night.. that is a very good write up
Old Aug 25, 2014 | 08:00 PM
fmc400's Avatar
fmc400
MSEE
When you say the 'I' terminal of "the switch," does "the switch" refer to the Hobbs-style oil pressure cutoff switch? Did you use the same switch as me?
What specifically is your concern - overloading the wire? If the 'P' terminal of your Hobbs switch runs straight to the pump, then yes, you'll burn up the harness. If you instead run the 'P' terminal of the switch to the coil of a relay like I did (along the lines of Jdeshler's suggestion), then there's no concern because relay coils draw very little current. That's the whole point of a relay (use a low-current circuit to switch a high-current load).
Old Aug 26, 2014 | 08:50 PM
1979 300i6's Avatar
1979 300i6
Thanks for the replys I'm pretty sure I have it wired correctly, but I will post some pictures of my set up tomorrow to see what you guys think.
offroadracer
May 12, 2011 04:11 PM
75Three90
1978 - 1996 Big Bronco
16
Apr 27, 2011 09:39 PM
mwstan
Oct 14, 2007 02:00 PM
iwkr40
17
Oct 8, 2006 11:37 PM
nalts
Jun 9, 2003 10:38 PM
