Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
code po351-354 mis fire help?
Old Feb 1, 2011 | 08:42 PM
robbie4door's Avatar
robbie4door
well this all started with my wifes escape started running rough in the rain one day.She said it was a little shuttering for about a minute then went well agin.
couple weeks later happened agin, in the rain?? then last week it was ever worse then the light on the dash came on... sh$%. when she was driving home the other night it was hissing from underneith and could bearly move wicked misfire... get home code reader says p351-p354 and a code316 to boot.so i changed all the plugs all the cop and now am replacing the pipe that must conect the front cat converter and the 2nd or fire wall side cat and then to the 3rd cat..right??.when the car was running exahst was comming from the steel braided peice of pipe that conects all the cats . any help would be great.will i get this dam thing fixed??
Old Feb 2, 2011 | 01:31 PM
robbie4door
anyone???please..
Old Feb 4, 2011 | 11:29 PM
250k93f350's Avatar
250k93f350
P351-p354 can be caused by the driver circuit in the pcm. What year is your Escape? The cure is a new pcm.
Old Feb 6, 2011 | 10:48 AM
robbie4door
its a 2005 escape 3.0
Old Feb 6, 2011 | 10:51 AM
robbie4door
my buddy said it seems like pluged cats but when i crank it over air comes out the tail pipe so?? dont know 3 cats = 2500 *&%ck.still think it might be the pcm.
Old Feb 6, 2011 | 05:38 PM
bmuhlbach's Avatar
bmuhlbach
if it was the cats it would run poor all the time I would think.Also when the cats plug they get super hot.Did you replace the lower intake gaskets?Another question for you to check into is maybe your cats are still under warranty from Ford.
Old Feb 6, 2011 | 08:28 PM
tonyford's Avatar
tonyford
You have one or more coil packs that have gone bad. Find out which cylinder or cylinders are misfiring and change out the coil packs.
If you keep running the vehicle with these bad packs, you will ultimately ruin your catalytic converter because of all the unburned fuel getting into it.
The running rough in the rain is a dead give away that one or more of your coil packs have gone bad. Or one of your ignition wires is shorting out. This only happens in damp, rainy, humid weather.
Been there, so I know what I am talking about. Luckily I had the packs changed out before permanent damage was done to the cats..
grumpy ole bear
Dec 30, 2014 06:26 PM
PRDATOR
Nov 30, 2011 06:41 AM
danger-ranger93
Oct 7, 2010 06:02 PM
05blackduramax
2004 - 2008 F150
Jan 5, 2010 03:22 PM
kdy72601
Apr 19, 2008 09:28 PM
