Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Lower Control arm broke!
Old Feb 6, 2011 | 07:31 PM
lamar804's Avatar
lamar804
Exclamation Lower Control arm broke!
Well, the (ex)wife was going to the store tonight and the lower control arm broke! So I had it towed to my house. I've never had something like this happen on a vehicle so I need some advice.
I started jacking it up, and realized the tire was not going up, I looked under and the ball joint is still in, but the arm has broken off! And, when the arm broke it ripped open the cv axle boot!
What would be the best way of getting the tire off? Has anyone ever had this happen?
Thanks
BTW: It's an '01 Escape
Old Feb 7, 2011 | 05:01 AM
tomw's Avatar
tomw
If you can fit it, a floor jack under the knuckle would be the best bet. If this is a corrosion caused problem, I would be looking for a recall or TSB that addresses the issue. This is a definite safety related failure. Can you imagine the carnage of a failure while driving on a freeway?
tom
Old Feb 7, 2011 | 06:02 AM
npccpartsman's Avatar
npccpartsman
I can also tell you that if you'll do a little research it's MUCH cheaper to buy and change the whole assembly with the ball joints already installed and they're NOT that hard to change.
Old Feb 7, 2011 | 10:48 AM
bmuhlbach's Avatar
bmuhlbach
I replaced my lower control arms is pretty easy.Two bolts hold it to the frame and 1 bolt thru the ball joint and I think the sway bar end link.I bought my 1st control arms from Car Quest they lasted under a year and the ball joints where totally shot.2ND set I bought from Ford hopefully these will last.
Joe04F150
20
Dec 2, 2014 11:24 PM
mcgowen980
1997 - 2003 F150
Nov 2, 2014 01:28 PM
vwovw
Sep 17, 2010 07:30 AM
WillFargo
Sep 10, 2010 10:23 AM
jessman1128
Sep 7, 2004 10:04 AM
