Horn Help!
Old Mar 10, 2003 | 06:12 AM
jcs1966's Avatar
jcs1966
Horn Help!
My 1966 has a horn on the pass side and it works. The drivers side has no horn and looks like no place to put one EVER! Did some trucks only come woth one horn??? The pass side has a bracket with two bolts under the battery and the horn is in front of a big hole in the metal that the radirtor bolts to. On the driver side I got two dimples that are in the correct location for the two bolts and a wire that isnt attached to anything close to where the big hole is. Does anyone have a driver side horn & bracket that works and is for sale?
Old Mar 10, 2003 | 11:42 AM
62stepside's Avatar
62stepside
Horn Help!
Don't quote me on this, but I think dual horns were an option. If you want to add one, you could just go buy a replacement horn from the parts house and bolt it in.
To test if the wire is actually a horn wire (without loosing your hearing ) Unplug the other horn, and use a test light. Have a friend, significant other, or get creative with a board and see if you have 12v on the wire when the horn button is pressed. (now reconnect the other horn)
Tyson
mikeo0o0o0
23
Apr 14, 2018 08:47 PM
Jolly Roger Joe
Jan 28, 2012 10:52 PM
berry1234
Apr 17, 2010 10:46 AM
betrayz
Jan 4, 2008 06:39 PM
jdmak68
1978 - 1996 Big Bronco
Dec 13, 2007 09:09 AM
