Horn and or Bracket Question...
Old Apr 16, 2010 | 12:52 PM
berry1234's Avatar
berry1234
Does anyone know if the horn bracket is a separate part from the horn and if it was used on any other Fords during the 73-79 years? I know my 78' has a empty spot for another horn on the core support on the driver side.
Old Apr 16, 2010 | 01:48 PM
spudgunman's Avatar
spudgunman
I thought it was one unit the horn is welded to the bracket last I remember. I had a 73 that had the dual horns and when I had to put her down and got my 78 it had one horn... so i moved the option to my new truck.
the 73 was a camper special XLT
the 78 was a ranger custom
the horn kit that I moved over came with a Y wire for the horn and the additional horn, it was a "plug and play" install.
the horns are a high and a low they bolt in the hole that you see on the cross-member
Old Apr 17, 2010 | 08:42 AM
Hyperactive460's Avatar
Hyperactive460
i just went out and looked, the bracket is spot welded to the horn. i did just what your thinking berry1234 and installed another horn on my drivers side of the core support.
Old Apr 17, 2010 | 10:12 AM
berry1234's Avatar
berry1234
Thanks guys.
Old Apr 17, 2010 | 10:46 AM
77460f150's Avatar
77460f150
The brackets are welded to the horns. Most of these trucks came from the factory with a single horn mounted on the right side, that was a "Lo" tone horn. There was an option offered for dual horns with the other one mounted on the left side, that one is the "Hi" tone horn. I just seen a set of dual horns for F-series trucks on fle-bay the other day complete with the stock wire harness. The dual horns sound like an old Buick or Cadillac. -Ed
Leatherneck007
Jun 26, 2014 05:43 AM
1957F100
Jun 28, 2009 12:00 AM
jdmak68
1978 - 1996 Big Bronco
Dec 13, 2007 09:09 AM
Dirt1dobber
Sep 23, 2006 03:12 PM
littleme13
Illinois Chapter
Dec 15, 2005 01:37 PM
