2003 6.0 will not start
Old Feb 8, 2011 | 11:05 AM
bismic's Avatar
bismic
Is the cable that runs from the passenger battery to the drivers battery in good shape?
One thing to keep in mind is that the FICM can be bad even if the voltage readings are in range. Not saying this is your issue, but it is just an unfortunate fact.
I would be thinking about the high pressure oil system as a culprit also. You will either need to do the air leak test or get diagnostic equipment (like an AutoEnginuity).
Did you read the thread that I provided as a link in post #2?
Old Feb 19, 2011 | 01:42 PM
mikegr's Avatar
mikegr
back again after having to replace a freeze plug in my wife's 1999 Sebring,
did the pressure test and have air coming out of the drivers side valve cover (the tube that goes up to the air intake). I reconnected the wiring harness to the high pressure relief valve, turned on the power and the air still comes out. Not sure yet what this means for repair.
the cable from the battery to battery shows about 9 Ohms,
also I have been reading error codes with a Super Chip 1704 tuner.
Old Feb 19, 2011 | 11:37 PM
matty169's Avatar
matty169
You found your problem..........
Problem found. Pull your valve cover and look at the braided hose to start with.
majestek12
Sep 16, 2015 02:06 PM
choctaw16
Apr 7, 2013 07:47 PM
Jnas860
Jul 2, 2012 02:19 PM
retiredinstructor
Mar 20, 2012 05:30 PM
polyeric
Jan 28, 2010 06:41 PM
