In the owners manual there is a process to turn off the seatbelt reminder. I will look for the process and post. it is straight forward and besides leaving the keys in the ignition mine never goes off any more.
This turned off the buzzer when I was just getting out and in while the engine was running. it eliminated the buzzer. These are work trucks and i agree it was bothering me when I would get out just to get the mail. so i tried it and it has taken care of the issue for me. i would give it a try and see. it takes about 3-5 min. and a lot of buckling and unbuckling but as i said i think it was worth it.
I recently disabled the keyminder/door buzzer on my '04 by removing the bottom portion of the steering column and removing a grounding wire connected to the key cylinder.
The buzzer is an issue with the lock tumbler. I have the same problem with mine, did a google search and found the answer. Just haven't done the work to it yet. Don't have a link but do a search, I'm sure youll find something.
