Sponsored by: Real Truck
NEED ELECTRICAL HELP
Old Feb 2, 2011 | 09:04 PM
fatjoe8504's Avatar
fatjoe8504
Exclamation NEED ELECTRICAL HELP
99 F350, plow. I had plow trouble today and changes the solenoid under the hood. Messing around with it, I tried to short it to see if that got it to work before replacing it. After the replacement, the battery light is on but the volt meter reads normal. The light is supposed to mean the alternator isn't working but if that was true the volt meter should be out of range I think. What did I do???
Old Feb 2, 2011 | 10:59 PM
Surge08's Avatar
Surge08
Check all fuses and connections you had taken off. Was this light on before you changed the solenoid?
Old Feb 3, 2011 | 06:16 AM
fatjoe8504's Avatar
fatjoe8504
No it wasn't. When we tried to short the original one we popped the fuse to the dash board and I replaced it, that's it. Then the light was on. It's had like 5 or 6 hours of run time after that with lots and lots of electrical running. I know it has 2 batteries but with the heat, the PLOW, lights, wipers, tunes, it should have died if it was going to.
Old Feb 3, 2011 | 09:24 AM
Surge08's Avatar
Surge08
sometimes there's an blown fuse for the cluster that will cause the light to stay on.
Old Feb 3, 2011 | 09:34 AM
F-series Fan's Avatar
F-series Fan
What do mean by shorting it ? Shorting circuits on newer vehicles can cause computer and other component damage leading to very expensive repairs, make sure you know the electrical system very well before jumping certain circuit types. Just trying to save you possible headaches.
Old Feb 3, 2011 | 04:52 PM
fatjoe8504's Avatar
fatjoe8504
conclusion
Yeah my alternator went. I had a 95 amp and put a big old plow on it. That'll do it. I have a 130 now
beersy50
15
Dec 26, 2013 08:38 PM
willrigdon
2004 - 2008 F150
Aug 6, 2011 07:55 PM
cornking
Jan 26, 2011 07:31 PM
powersfab
May 25, 2009 12:33 PM
Cracker289
Electrical Systems/Wiring
Dec 29, 2004 01:04 PM
