Offroad & 4x4
Power steering upgrade
Old Feb 7, 2011 | 03:15 PM
DILLIGAF13's Avatar
DILLIGAF13
No luck on the locating a cardone or napa for the direct bolt on swap. I may have a line on a late 80's V8 econoline in a junk yard. If its still there Wednesday will the brackets from any donor econoline V-8 work on a 460? I also want new hoses so do I need the original hoses off the 96 F250 or the hoses off the 80's econoline or something else? Thanks.
Old Feb 7, 2011 | 03:35 PM
fatdan460's Avatar
fatdan460
i believe the brackets are engine specific. so if the van has a 460 it would work on a 460, but not on a 351w. either way i'd nab the hoses from the van while you are there just in case they are different on the pump end.
Old Feb 7, 2011 | 05:18 PM
alpha/omega's Avatar
alpha/omega
^^^ didnt I say that like 10 post ago?
: piratesalute:
Old Feb 7, 2011 | 05:24 PM
fatdan460's Avatar
fatdan460
: piratesalute:
I've got a baby dick!
Old Feb 7, 2011 | 05:35 PM
alpha/omega
9lbs and 20"?
Your mother has been telling you stories about me again, eh?
Old Feb 7, 2011 | 05:49 PM
fatdan460's Avatar
fatdan460
actually she did say something about you the other day.....
Old Feb 7, 2011 | 06:58 PM
alpha/omega
Naaa, she just told you that so you wouldnt be pissed.
Old Feb 7, 2011 | 07:05 PM
fatdan460's Avatar
fatdan460
:flipoff:
fatdan460's Avatar
fatdan460
:flipoff:
Old Feb 7, 2011 | 07:24 PM
alpha/omega
Originally Posted by fatdan460
:lovesthis!:
Old Feb 7, 2011 | 07:37 PM
fatdan460's Avatar
fatdan460
site has been weird again today, and i somehow made another double post, hmmmm.......
Old Feb 7, 2011 | 09:03 PM
itsnotanova's Avatar
itsnotanova
So no ford truck ever came with the saginaw pump? Only the vans and some cars?
Old Feb 7, 2011 | 09:04 PM
  #28
DILLIGAF13's Avatar
DILLIGAF13
I've got a guy with one that he says fits 88-92 460 w/EFI. Any idea if this will bolt on the '96 460?
Old Feb 7, 2011 | 09:13 PM
  #29
fatdan460's Avatar
fatdan460
it should fit all 460's efi or not, the only difference is the bolts may be a different size, but all the holes are there on all the heads/blocks.
Old Feb 8, 2011 | 07:31 PM
  #30
DILLIGAF13's Avatar
DILLIGAF13
Alright. I ordered a power steering assembly (bracket and pump)from some online parts locator. The issue is it doesn't come with hoses. I thought I read somewhere that the stock hoses didn't fit correctly but that hoses from a '79 F150 worked.
