Sponsored by: Real Truck
Front end bottoms out
Old Jan 31, 2011 | 06:29 PM
Skinner F350's Avatar
Skinner F350
Wondering if anyone else has the problem of the front end bottoming out even by going over a small bump. On a 2007 F-350 6.0L with a Procomp 6" lift kit. changed out shocks 3 times already with procomp replacements. Usually good for about a month...
Old Jan 31, 2011 | 06:53 PM
F350-6's Avatar
F350-6
Welcome to FTE. If you've got a 6" lift, what exactly is bottoming out?
Old Jan 31, 2011 | 07:06 PM
loganworks's Avatar
loganworks
cant see it bottoming out but it could be the opposite with the shocks. They may not be long enough and are hitting on the rebound.
Old Jan 31, 2011 | 07:28 PM
Skinner F350
It seems to be the stops just in behind the coil springs. there are two 4" stops that would hit the seats on the axle. Ford dealer say that this should not happen but it has already crushed the vacuum hoses going to the hubs. I was thinking that they maybe put the wrong stroke of shocks on. Not sure how long of stroke they should be. Phoned Procomp but they wouldn't tell me anything because they said that they only deal with customers, like dealers and garages. Not individuals.
Old Jan 31, 2011 | 07:57 PM
F350-6's Avatar
F350-6
Did they put oversize bump stops in with the lift? Do you have the part numbers for the springs? Maybe they sold you the wrong springs. Do you have a plow or anything heavy up front?
Old Jan 31, 2011 | 08:18 PM
Skinner F350
Nothing on the front of truck except push guard. Will have to check the springs. I had a 02 F350 and a 05 F-350 with the same lift and no problems. But ofcourse the 02 had leafs in the front. The shocks also keep pounding out the bushings.
Old Jan 31, 2011 | 10:59 PM
99f350sd's Avatar
99f350sd
Pull one end of the shock off and do some measuring to see if the shock will bottom before the suspension will. I can't bottom mine even with a plow..Something's hitting...
Dick
Big Red F250 SD
6.7L Power Stroke Diesel
26
Dec 17, 2020 09:57 AM
jfletcher72
Jun 20, 2016 03:13 PM
BIGTRUCKBIGRV
May 13, 2015 05:03 PM
KSims1868
Feb 23, 2011 11:38 AM
bigjp
Offroad & 4x4
Jan 5, 2010 02:39 PM
