Need help venting new transfer case
I have a 92 f150 4x4. My transfer case ate itself so i purchased a used replacment from a reputable 4x4 shop. They opened it up and checked everything out before selling it to me. The issue i am having is the hole for the vent tube should be fine threaded but someone has tapped the hole for what looks to be a 3/8 coarse threaded bolt. So now i am not sure how to vent this thing. There is however a second fill plug (mark fill for pto only) on the front just to the left (driver side) of the normal vent and shift sensor toward the top of the transfer case. Does anyone know what this is and if I can use this location to vent it or can I just run the transfer case with out the vent. This truck is just my project and won't be leaving this area for higher or lower elevations, so theoretically I should not need the vent. Can someone either support or veto my theory so I don't shell another transfer case. Thanks for any input.
Well so far so good. There is a second fill hole on the front of the case about 1" lower and 3" toward the driver side of the truck that I used for the vent. I will probably have to get a longer hose so I can run it under the shift linkage and away from the front driveshaft. Other than that I will just keep an eye on the fluid level for a while to make sure there are no issues. Thanks for the help.
FORD Blue blood
08-02-2011 07:05 PM
Highboy74
11-04-2010 09:17 PM
4onfloor
02-18-2010 04:26 PM
clunker86
02-27-2007 06:35 PM
