Transfer Case Leak-Vent???
Old Apr 7, 2007 | 08:16 PM
Brother65's Avatar
Brother65
I noticed my transfer case was wet today, and on further inspection it was bone dry. The rear seal is where it appears to be leaking. I had a similar problem with the rear axle on my last truck. It turned out to be the relief vent was plugged with mud. I looked but couldn't find a vent. Does this model use a vent? If it does, can anyone tell me where it is located? I want to check that out before I change the seal. It is a 2000 Ranger 4x4. Thanks.
Old Apr 8, 2007 | 09:03 AM
crazypaw's Avatar
crazypaw
Wink
hi Brother65
Did you check in:
https://www.ford-trucks.com/forums/1...formation.html
or
https://www.ford-trucks.com/forums/forum69/
Last edited by crazypaw; Apr 8, 2007 at 09:05 AM. Reason: added more pertinent info
Old Apr 8, 2007 | 09:16 AM
Brother65's Avatar
Brother65
Yes. I didn't find anything.
Old Apr 8, 2007 | 10:24 AM
fflintstone's Avatar
fflintstone
I don't know for sure, but most often, vents on these under chassis units like the rear and front axles consist of a tube running up from a nipple on the housing to the frame with a little screen cap on it. If it's plugged you'll know by removing the upper fill plug and using a length on tubing(tygon is good) with a wadd of bubble gum wrapped around the end for a seal an see if you can pressurize the case with your breath. It should'nt hold pressure as the t-case should be vented. Feel around the top of the t-case for a nipple or a rubber tube connected to it. Follow the tube to the end. There should be a screen cap on the end of it. The silly thing might run all the way to the engine compartment. Pull it off and retest with your bubble gum hose
Just an idea. Good luck
Fred
Old Apr 8, 2007 | 08:46 PM
Brother65's Avatar
Brother65
I'll look again, but I didn't find one. I thought that maybe Ford did something different on these.
Old Apr 9, 2007 | 10:46 AM
aquanaut20's Avatar
aquanaut20
Seem to remember seeing it on the driver side front of the T/C
Old Apr 10, 2007 | 07:10 PM
Brother65's Avatar
Brother65
Found it. Like you said, front drivers side, out of sight. Unfortunately it was clear. Thanks for the help.
bpimm
Dec 22, 2015 05:45 PM
JoeJJones
Aug 27, 2014 09:27 PM
cherrybomb37
Jul 28, 2014 08:19 AM
paddler
Sep 7, 2013 02:28 PM
recluse
Apr 18, 2010 05:25 PM
