ignition question
Old Jan 31, 2011 | 04:19 PM
attam's Avatar
attam
ignition question
hi I have an 82 f150 4x4 I6 I was looking at different post about dura spark II as far as I can tell my truck should have this set up. Is that correct? It is stock right now but soon to rebuild engine and have head work done have a set of efi manifold getting offy dp intake and edlebrock 1403 carb with heated carb spacer. If I do have duraspark II setup is there anything I will/ should replace / buy for what I am planning on doing. I also am going to recurve dizzy.
Old Jan 31, 2011 | 04:42 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The 82 300/4.9L used a DS2 ignition from the factory. Other than replacing any parts that are in questionable condition, it should be good to go.
Of course, there's always a chance that someone has modified it during the last ~30 years, and something else is now in place.....
Old Jan 31, 2011 | 05:32 PM
AbandonedBronco's Avatar
AbandonedBronco
Exactly what Rogue_Wulff said.
The Duraspark II ignition was used until '83. The only thing you may need if you're recurving it is some recurve springs.
Mr. Gasket 925D is generally the favored set. Some sites state that it's only for the smaller I6s, but it will work for your application.
Old Jan 31, 2011 | 07:20 PM
attam's Avatar
attam
ok how do I make sure I have the correct components? It seems to have a lot of vacuum lines will I need all of these once I change carbs? Thanks for the info
Old Feb 1, 2011 | 07:35 AM
AbandonedBronco
Once you go through the conversion you're doing, most of the stock components will no longer be used. At that point, the vacuum line routing becomes incredibly simple.
One line for the power brake booster, one line for the PVC, and one line for the distributor's vacuum advance.
Old Feb 1, 2011 | 08:35 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Plus one for the A/C vent controller...
And Offy C ftw!
Old Feb 1, 2011 | 10:23 AM
Wyowanderer's Avatar
Wyowanderer
And one for my EGR....
Old Feb 1, 2011 | 10:31 AM
Harte3's Avatar
Harte3
My '83 came with DS2. I Think TFI came out with the feed-back carb.
Old Feb 1, 2011 | 11:30 AM
AbandonedBronco
It'd be a bit of work to get an EGR setup back underneath a 4bbl, but I'd like to try it sometime.
Old Feb 1, 2011 | 04:26 PM
attam's Avatar
attam
ok i go to parts store and buy an oem ignition module that would be a duraspark? and any prefrences on coils?
Old Feb 1, 2011 | 04:31 PM
AbandonedBronco
Is your ignition module bad? You can have it tested. If there's nothing wrong with it, a replacement won't buy you anything.
Old Feb 1, 2011 | 05:50 PM
attam's Avatar
attam
no it did go bad about 4 months ago when to tractor pulls and when i went to leave nothing and i got an oem style to replace it i was just making sure wouldnt need to buy a certain brand
Old Feb 1, 2011 | 07:36 PM
AbandonedBronco
Ahhh...
Yeah, just double check where the manufacturer gets them from. If they're made in China, those aren't known to last all that long.
Old Feb 2, 2011 | 02:48 AM
attam's Avatar
attam
k thanks for all the help no off any one selling a offy dp intake
jack orchard
Nov 18, 2017 08:09 PM
Qwatali Hunter
May 31, 2011 09:27 PM
61UniB100
21
Oct 22, 2008 06:41 AM
ClatonK
Electrical Systems/Wiring
Jan 4, 2004 03:51 AM
liljpy
May 27, 2003 01:44 PM
