Sponsored by: Real Truck
New Instrument cluster
Old Jan 30, 2011 | 11:42 PM
SapperCornfed's Avatar
SapperCornfed
Question New Instrument cluster
Does any know how to put the correct mileage on another gauge cluster I had to get a new one and I didnt know if I could put the mileage that was on my original gauge cluster?
Old Jan 31, 2011 | 12:08 AM
CraigOutdoors's Avatar
CraigOutdoors
I would think you'd need to get the odometer unit out of the old one and put it in the new one. Odometer manipulation is generally frowned upon, so I'd think they would make it fairly difficult to change the mileage reading.
Old Jan 31, 2011 | 12:10 AM
keithww's Avatar
keithww
I would take it to a Speedometer repair shop. You might need to sign some paper work.
Old Jan 31, 2011 | 12:20 AM
SapperCornfed
Thanks for the input I aint tryin to lie about my mileage I'm just trying to get my original mileage put on my new one but thank ya'll for all the input
Old Jan 31, 2011 | 12:24 AM
Skip1970's Avatar
Skip1970
i was told the gauges are part of pats and the vehicle wont run without the original gauges in place
Old Jan 31, 2011 | 01:31 AM
orng1's Avatar
orng1
I've seen cars with replaced clusters with a stocker on the door or frame. Original milleage + odometer milleage.
Old Jan 31, 2011 | 01:58 AM
twags6's Avatar
twags6
Thats what I always heard. You get the original mileage recorded on that sticker and add the new mileage on the odometer to it. Maybe the digital ones can be adjusted if you get a new one at 0 miles, but most of them have some sort of tamper feature that shows up if you fiddle with them. I know some odometers show silver lines between the numbers if its tampered with.
Old Jan 31, 2011 | 07:56 AM
SapperCornfed
Thank ya'll for all the input I like the sticker idea thats prob what I'll go with.
Old Jan 31, 2011 | 08:18 AM
2002 F350V10's Avatar
2002 F350V10
Automotive rebuilders do it all the time. Very common. There are mail order services available to anyone where you send them the speedo cluster, along with mileage requested. They have special programming on a pc and adapter cords which plug from the printer port of the computer to the speedo cluster assembly. They then have the ability to change the speedo mileage to whatever is desired,on a bench , then send it back. It is legal and there is no crime unless someone along the was uses this to misrepresent mileage.
Old Jan 31, 2011 | 10:43 AM
SapperCornfed
do you know any places that would do that and thank you for your input
Superduty15379
Jan 15, 2015 08:03 AM
Gembone
17
Aug 1, 2013 05:55 PM
thejim42
May 12, 2013 10:14 AM
phillip_brame
2004 - 2008 F150
Mar 29, 2010 03:28 PM
stangfan78
Dec 6, 2006 07:55 AM
