Purolator fuel Filter problem
Old Jan 29, 2011 | 09:17 PM
4x42001's Avatar
4x42001
Wink Purolator fuel Filter problem
Hi! newbi here.
Recently purchase a Purolator fuel filter for my fleet vehicle, 2001,
Ford Ranger, 4x4, with Auto, Extra cab, and 4.0 Liter engine.
With no garage to do the work, and winter snow/cold all around I decided
to let a local Mech. do the install with this filter.
Well he calls/pages me, and tell me, no go, but was able to get the right
filter for my pickup. I have great represt for this Mech.
I re-check on line with Advance Auto, and they list it for my truck.
Could someone out there tell whats going on. Thanks.
Purolator fuel filter, part number F55523
Old Jan 29, 2011 | 11:23 PM
MikeB 88's Avatar
MikeB 88
Binged the P/N in your post. This was in the first return.
Automotive Filters Direct - Air Filters, Cabin Air Filters, Fuel Filters - F55523 - Fuel
Old Jan 30, 2011 | 06:17 AM
greenpus's Avatar
greenpus
the ford filter has a mounting bracket welded to the filter. if the picture of the filter you bought is accurate then the one you bought does not have that bracket which makes it the wrong one. Not sure why puralator went cheap and didn't make the part OEM.
Old Jan 30, 2011 | 06:54 AM
monsterbaby's Avatar
monsterbaby
Possibility of a miss boxed part too. I have had it happen on occasion over the years. Go back to the store you bought hte filter from and have them pull another filter for your truck from the shelf and compare it to the one you already have and see if they are identical.
Old Jan 30, 2011 | 07:15 AM
03 Maz B23's Avatar
03 Maz B23
If I remember correctly the filter snaps out of the bracket allowing the original bracket to be used for the replacement filter (unless too rusted out). Probably why the replacement didn't come with it. Only other reason the Purolator wouldn't work is if it didn't have the same number of fittings as original. Also depending on the mechanic some prefer to use their own parts due to the markup they can claim for added profit in cost of the job.
Old Jan 30, 2011 | 10:41 AM
pawpaw's Avatar
pawpaw
If the vehicle was mfg after 5/14/01, the Purolator site has an F65376 fuel filter specified & it has a mounting bracket attached.
Edit: Click on a part# & it'll put up a part pictorial.
Application Guide Results
BTW, welcome to FTE.
pawpaw
Oil & Lubrication
Apr 10, 2016 01:54 PM
TexasGuy001
16
Oct 3, 2009 06:29 PM
rsylvstr
Oil & Lubrication
Jan 5, 2007 07:49 PM
SemperFi
Jan 1, 2006 01:04 PM
Pickupman2004
Jun 2, 2004 01:51 PM
