6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Ford will not pay for radiator
Old Jan 29, 2011 | 01:38 PM
Buckbuster's Avatar
Buckbuster
Last fall I had to have the radiator replaced on my 08 F250 --it was leaking due to a bad crimp on the lower drivers side. A problem long known to Ford and addressed in Aug of 2007 - for radiators that had not been installed. Those of us who had trucks in service prior to that- were pretty much ignored while I can only assume Ford hoped for the best <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
At the time of the failure my truck had 32K miles but was 45 days out of the 36 month warranty. I call the Customer Relations Center and was to "sorry" (Ford wins) - I added the Ford wins part. <o></o>
Wrote a letter and received a response today - which coveys "we told you on the phone we weren't going to pay & we meant it"<o></o>
I am disappointed EDITED
Edit by Crazy001: Discussing lawsuits or other legal actions is against the guidelines.
Last edited by Tom; Jan 29, 2011 at 07:31 PM. Reason: Legal actions are against the guidelines!
Old Jan 29, 2011 | 03:55 PM
cheezit's Avatar
cheezit
did you have a failed t-stat.
the issue is not from a crip failing at all.
Old Jan 29, 2011 | 06:50 PM
senix's Avatar
senix
i suppose that some of this might have also been due to the venturi-T recall not being performed before the in-service date?
Mine venturi T was done within a few days after me buying the truck. I now have almost 47K/1200 hours and I have the orginal radiator.
Old Jan 29, 2011 | 07:46 PM
Tom's Avatar
Tom
Unfortunately radiators going bad are a common problem with this engine. Unless you have an extended warranty they will not cover it after the 3/36 warranty has expired.
It stinks, but there isn't much that can be done about it now.
Old Jan 29, 2011 | 07:58 PM
Stalwart's Avatar
Stalwart
They covered mine at 39,000 without extended warranty.
Old Jan 29, 2011 | 08:00 PM
cheezit's Avatar
cheezit
we at the dealer were able to do that do to a miswriten tsb at the time. that tsb has sence changed and is no longer valid. ford caught there mistake.... at least on the writing of the tsb
Old Jan 29, 2011 | 08:01 PM
Stalwart's Avatar
Stalwart
I'm glad I have a new one in the box that only cost me $400 then.
Old Jan 29, 2011 | 09:28 PM
StanleyZ's Avatar
StanleyZ
I don't get what you're upset about. If the rad had failed the day before the 3 years was up would you have told them to "forget about it, my warranty is almost up anyway"? A contract is a contract, right? They should have checked the stats though, like someone above said, that's the real problem and if they failed then I think they can replace the rad. Of course maybe they did check them.
Old Jan 30, 2011 | 06:36 AM
Buckbuster's Avatar
Buckbuster
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o> </o>
Yes a contract is a contract - but the poor crimp was a known defect - corrective actions were taken by Ford to re-inspect radiators not yet installed. Yet this left some truck already in service without any corrective actions. Known defect - with some trucks ignored = negligent. I will continue to pursue next level actions to seek an equitable resolve.<o></o>
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=Picture_x0020_2 style="VISIBILITY: visible; WIDTH: 255.75pt; HEIGHT: 192pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1026"><v:imagedata src="file:///C:\Users\DEWAYN~1\AppData\Local\Temp\msohtmlclip1\ 01\clip_image001.jpg" o:title="IMG_9823 - Copy"></v:imagedata></v:shape><o></o>
<v:shape id=Picture_x0020_3 style="VISIBILITY: visible; WIDTH: 255.75pt; HEIGHT: 192pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1025"><v:imagedata src="file:///C:\Users\DEWAYN~1\AppData\Local\Temp\msohtmlclip1\ 01\clip_image002.jpg" o:title="IMG_9824"></v:imagedata></v:shape><o></o>
Old Jan 30, 2011 | 06:46 AM
Buckbuster's Avatar
Buckbuster
I am upset that there was a known defect that Ford's corrective action plan left some trucks in the field without addressing the issue - and that I ended up with one of those units. I wouldn't be nearly as upset if it was your truck.
Old Jan 30, 2011 | 07:01 AM
senix's Avatar
senix
check your PM's.
Old Jan 30, 2011 | 07:14 AM
Buckbuster's Avatar
Buckbuster
SENIX -I'm just not that smart - PM's ????
pre menstrial ? post menstrial? preventative maintenance?
Old Jan 30, 2011 | 07:16 AM
senix's Avatar
senix
cute, private messages.
Upper right hand corner of the screen, just under your user id.
Old Jan 30, 2011 | 07:21 AM
Buckbuster's Avatar
Buckbuster
thanks - was there earlier this am -
really wanted Ford to step up - but I will follow through with a complaint.
Kart18
437
Mar 14, 2018 05:20 PM
AL_AWAJI
Dec 9, 2012 09:21 PM
bobbytnm
57
Jul 26, 2011 08:00 PM
Lubbz
Nov 20, 2009 04:24 PM
RÖENTGEEP
15
Dec 22, 2008 07:02 PM
