Edge Insight CTS - Set-up Help
Old Jan 29, 2011 | 12:43 PM
401-k's Avatar
401-k
A couple questions:
1 - In the standard configurations I don't see a reading for Engine Oil Temp. How do I get that to display.
2 - What other vitals have ya'll added to the standard monitoring?
3 - Do I need to unplug it or turn it off when I shut down the truck?
Any other new user tips are appreciated.
Old Jan 29, 2011 | 12:51 PM
Zmann's Avatar
Zmann
it should have ford pids to select from after you plug it into the truck and make the proper selections the first time
I watch EOT .ECT .boost . batt voltage,trans temp I have a standalone EGT gauge if I didn't I would pick that over batt voltage
did u update when u got it ?
it will come on and off automatically after the first three user agreements
Old Jan 29, 2011 | 12:56 PM
401-k's Avatar
401-k
No, I did not update it. I just plugged it in. How do you update it? I am installing the "mystyle" software on my pc now. Likely somehow through that, huh?
What is a pid? I just picked Ford and there was no other options from there, but maybe if I connect to PC and update it, you can further select from there?
Old Jan 29, 2011 | 01:02 PM
Zmann's Avatar
Zmann
I would update it tells you to do this when new even
it is thru the computer go to their site if u need the software it is not the same as the mystyle
what gauge pattern did u select?
Old Jan 29, 2011 | 01:32 PM
401-k's Avatar
401-k
I played around with the analog and the one that shows 8 readings, they are small and hard to read.
Old Jan 29, 2011 | 01:39 PM
Zmann's Avatar
Zmann
I use the analog and if u want to change a PID ("Parameter IDs", are codes used to request data from a vehicle)
just touch the one you want and a new screen will pop up and you can pic from there
Old Jan 29, 2011 | 02:04 PM
mixerdrvr's Avatar
mixerdrvr
Zmann, does it have the maint reminder active?
Old Jan 29, 2011 | 03:18 PM
Zmann's Avatar
Zmann
I do ,, I set the oil life and a few other things that I can't remember right now lol
it's all up to you what you pick and intervals
AzApache
Aug 8, 2015 10:39 PM
rduncan530
Nov 13, 2010 01:44 PM
Fifty4F100
Tennessee Chapter
13
Jul 7, 2008 03:11 AM
JICASE
Mar 2, 2008 01:51 AM
joewaldner
Sep 3, 2007 08:16 PM
