Sponsored by: Kumho
2WD prevention for mud.
Old Jan 28, 2011 | 10:31 PM
kayemdee's Avatar
kayemdee
I wasn't sure where to put this, but here goes...
I bought a 2WD truck in October. Since I know little to nothing about cars/trucks and that's kind of my grandpas area of expertise he helped me shop around...I ended up getting an '04 F-150...with 2wd. I asked and asked and asked if that would be a problem for my purpose of having a truck - pulling a horse trailer. I was assured it would be fine. Now I'm nervous... I've gotten stuck a few times, one time totally caused by my error and the other was kind of a fluke thing.
SO now I'm wondering if it WILL be okay for it's purpose. I know it can pull the trailer fine, but I'm thinking of when I have to park it in a pasture area, if I'll get out okay if it's recently rained/muddy/etc. Is there anything I can do to prevent getting stuck or carry along in case I get stuck? I've been toying around with the idea of selling it and getting something 4wd, but I'd really rather not...I've grown attached to her...
I feel silly posting this because I know I must sound like an idiot, but that's why I came on here...trying to learn more about my truck before I start pulling precious cargo.
Thanks!
Old Jan 29, 2011 | 06:12 AM
JWA's Avatar
JWA
Well if your twice stuck problems are once your own doing & then a fluke there's probably nothing to worry about. If a trusted advisor suggested this particular truck for purposes of towing a horse trailer not sure why you're doubting that advice so quickly.
Look around at what others are using---chances are you'll find many many very similar to your rig. I've seen ill-advise people pulling 2 horse trailers with nothing more than 1/2 ton pick ups and vans, some using the older large station wagons from the 80's.
Sadly there's no device or magic trick to undo something silly we do so planning ahead and carefully surveying where you park will go furthest in "mud prevention" Thing is I've seen more 4 WD's stuck simply because the drivers believe there's no place they can't get themselves out of----proves to not be true so often yet time and time again we see it.
Better luck next time!
Old Jan 29, 2011 | 08:54 AM
Ford_Six's Avatar
Ford_Six
Tires can make a huge difference. If you have highway tread, then it will get stuck really quick. I run a highway tread on the front of my truck, but a slightly aggressive all terrain on the rear.
Old Jan 29, 2011 | 11:04 PM
ray bennett's Avatar
ray bennett
What he said. Get rid of the straight tread and get an all terrain pattern. also for field use a wider rear tire would be better. It will give you more surface area too grab and less rutting of the field. I run BFG all terrains on all my farm trucks.
Old Jan 31, 2011 | 02:11 PM
Derrick@TireRack.com's Avatar
Former Vendor
I would keep the truck and get yourself a set of good all terrain tires for it. That would help for sure.
http://www.tirerack.com/a.jsp?a=BZ1&...tination+A%2FT
http://www.tirerack.com/a.jsp?a=BZ1&...rrain+T%2FA+KO
http://www.tirerack.com/a.jsp?a=BZ1&...l=Grabber+AT+2
Rasalas
Oct 6, 2016 07:45 PM
ElleDivaNavi01
Sep 11, 2016 08:25 PM
amaterasu
New Member Introductions
Mar 15, 2016 04:56 AM
olblue77
Feb 12, 2015 10:00 AM
LukeN
Computer Chips & Tuners
Oct 10, 2006 11:10 AM
