351M build
Old Jan 28, 2011 | 05:58 AM
cdawley4's Avatar
cdawley4
351M build
Hi,
I am interested in building my 351M a little and wanted to know if these parts would be good candidates. My main goal is to add a little performance to it and to get rid of the smog stuff and advance the timing.
My parts I have chosen are
Summit Racing SUM-G6505 timing set
Summit Racing SUM-K5200 Cam and Lifter Kit
Summit Racing SUM-M08600VS 600 cfm Carb
Weiand 8010 Action Plus Intake
Any suggestions would be greatly appreciated.
Thanks,
Chris
Old Jan 28, 2011 | 08:43 AM
mark a.'s Avatar
mark a.
Headers....
maskedman's Avatar
maskedman
You will need to get a new compatible valve spring and retainer set for that cam arrangement.Look at this kit from Summit,P/N is CCA-K32-221-3.The timing set you have picked out is no better than stock.These are very mild treatments for this engine,and nothing truly wakes them up like a much needed higher compression ratio.And as mark says,headers!!
Old Jan 29, 2011 | 12:34 AM
cdawley4's Avatar
cdawley4
I plan on putting headers on it. The ones I had in mind are the SUM-G9034, which are made by Flowtech. I can probably step those up to Hedman's or Hooker's for better performance if need be.
I chose the Summit headers because it already comes with the reducer to reduce the 3" collector down to the 2.5" pipe.
Old Jan 29, 2011 | 09:39 PM
cdawley4's Avatar
cdawley4
So far, I have priced out the specific components from the Comp Cams K32-221-3 Kit. I know it costs about $378 for the kit, but wanted to break it down into specifics, as funds are limited.
I downloaded the Comp Cams online catalog and found out the individual part numbers and priced them out at Summit Racing, being that there is a Summit Racing around the corner from my house.
Here are the Part Numbers and prices for each component.
Cam & Lifter Kit P/N CL32-221-37 $199.95
Timing Set P/N CCA-3221 $ 32.95
Valve Springs P/N 940-16 $ 82.95
Valve Spring Retainers P/N 743-16 $ 51.95
Valve Locks P/N 601-16 $ 5.95
Valve Seals P/N 502-16 $ 9.95
Total $383.70
I know this is a little more than the kit, which also includes the assembly lubricant. In regards to the assembly lubricant, which lubricant would be good?
Also, Would it be necessary to change the stock rocker arms to the Comp Cams P/N 1411-16 rocker arms?
I want to try and do everything to the engine the first time so I don't have to do it later on down the road. One other thing to point out is that the engine only has about 60K original miles on it.
Thanks,
Chris
Old Jan 30, 2011 | 01:12 AM
smokeyb97's Avatar
smokeyb97
Total $383.70
Thanks,
Chris
As far as the Comp 1411 rockers, you'll have to have the heads milled to accept these rockers. I've got a new set of the 1411 rockers I've never used if your interested in a good buy.
EightGodzillas
Nov 28, 2016 11:11 PM
ola1234
Nov 23, 2016 09:01 PM
Buyerz
Jun 19, 2016 09:45 AM
fordf2501
May 3, 2016 10:59 AM
teamshadyinc
24
Dec 3, 2010 10:20 AM
