Door Adjusting. Need Help Bad!
Old Mar 9, 2003 | 02:44 PM
alan v.'s Avatar
alan v.
I have been rebuilding a 78 4x4 F150 and recently I had to put a door on the right side. I can not seem to get the door to go up or down. It needs to go up about 1/2 to an inch because the latch is about 1/2 to an inch below to striker. Please help if you can.
Old Mar 9, 2003 | 05:08 PM
sparky's Avatar
sparky
Well if the body lines are lined up with the body lines on the cab....just adjust the striker up.
Loosen it off and it adjustable up/down and in out.
Old Mar 10, 2003 | 02:51 AM
alan v.'s Avatar
alan v.
Thats just it, the body lines are not lined up they need to go up half an inch or so. I don't know what to do!
Old Mar 10, 2003 | 07:16 AM
Torque1st's Avatar
Torque1st
Posting Legend
Adjust the hinge mount bolts either on the door or fender side as required. Unless your cab or door has been seriously jacked with in an accident they WILL line up. Align the body lines first, then get the gap right all around, then go for the striker bolt. Make sure you have a good striker bolt with the plastic sleeve in good shape on it.
oldman1953
Feb 23, 2014 03:48 PM
53pickemuptruck
27
Feb 22, 2009 10:14 AM
Viper-IGN
May 7, 2004 08:44 PM
fatdaddy
Paint & Bodywork
Oct 30, 2002 03:08 PM
