Heater / AC Vacuum line Help
Old Jan 27, 2011 | 07:31 PM
MNDiesel2's Avatar
MNDiesel2
So I was troubleshooting my 4 wheel drive solenoid (solenoid is junk I believe), and I started looking at the vacuum lines to the heater / ac controller. The black one apears to be the vacuum feed (feeds off same line that goes to the 4 wheel solenoid swithch) but there is a grey one in the same area tied together, maybe a return line?? (going to the heater /ac control area), and it was laying on top of the motor, and not hooked up to anything..
Well the grey one wasn't plugged into anything, where does this go??
Could someone take a look and post back here, I'm thinking it should go to the vacuum canister, but can't find a port or fitting that it should slide onto.
Anyone?
Thanks,
Chris
Old Jan 27, 2011 | 08:38 PM
bismic's Avatar
bismic
Coolant supply valve to the heater core?
Old Jan 27, 2011 | 10:45 PM
MNDiesel2's Avatar
MNDiesel2
Thanks Bismic. I went and looked again, and that seemed to be the right amount of reach on the line. Sure enough it wasn't on there. What is it there for anyhow, stop the coolant from entering heater core until you have it warmed up??
Old Jan 28, 2011 | 04:50 AM
bismic's Avatar
bismic
Keeps the hot coolant from circulating through the heater core until you call for the heat from the climate controls.
Old Jan 28, 2011 | 10:33 AM
riverstroker04's Avatar
riverstroker04
bismic the one on my truck is open even when its not on heat the air is not as hot but not as cool as it should be. I just did egr,studs could I have hooked something up wrong some place else??
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
ydaveitsu
158
Jan 10, 2023 05:10 AM
Bubba Jones
1978 - 1996 Big Bronco
24
Mar 19, 2014 10:55 PM
Alan17
Oct 13, 2013 04:07 PM
AQUARIES1
27
Jan 8, 2004 08:35 AM
