drivers side injectors dead
Old Jun 18, 2015 | 06:55 PM
dcelrod's Avatar
dcelrod
97 f350 ts chip straight piped and 6637. Was running fine when I parked it last night and started it this morn and is running very rough and check engine light is on. When I unplug the valve cover harness plugs on the drivers side nothing changes but, the passenger side both will make a change. Any ideas? Tia.
Old Jun 18, 2015 | 07:17 PM
Lliamspop's Avatar
Lliamspop
Mine started running rough and only one side of the motor was running it turned out to be my idm. Once that was replaced all was well. Can't say that's your problem but that's what happened to me.
Old Jun 18, 2015 | 08:51 PM
96F250SD's Avatar
96F250SD
Reply/Question
Did it rain over night? My IDM got wet and only ran on the back 4 cylinders. New (to me) IDM and now it purrs like a knocking kitten lol
farmert's Avatar
farmert
Are the harnesses on the drivers side melted, or the pins burned? The IDM can shut one bank down to prevent damage to itself from damaged wiring. You might want to pull the valve cover and check the UVC harness to the glows, and injectors for damage, as that can cause the shut down of that bank.
Old Jun 18, 2015 | 09:30 PM
dcelrod's Avatar
dcelrod
I put a new uvhc on that side and its the same one of the glow plug pins did short a few months ago but I unhooked the glow plug relay and its been running fine until this morning I drove it last night and got in it this morn to leave and it was like it is now as soon as I started it.
JT250
Mar 19, 2017 02:57 PM
75Three90
Mar 16, 2013 09:24 PM
rawlsrc
Aug 4, 2012 12:12 PM
2002f250xlt
19
Feb 15, 2012 07:29 PM
johnsonswamp
Oct 23, 2008 06:32 PM
