Need head bolt suggestions
Old Jan 27, 2011 | 09:37 AM
Pa Rambler's Avatar
Pa Rambler
My 6.0 is at the dealership for the second time because of a blown head gasket. I asked in a seperate thread yesterday for suggestions as to what I can do to keep this from happening again because my warranty runs out in September. Truck has only 55,000 miles on it but it's an 06'. Couple of suggestions were to use ARP head bolts. I talked to the service manager last night and he said they might be willing to do that but he would like me to get him more info. So I'm looking for that info. I was hopeing to find some documented instances where these or other suggestions have worked. Even if it's just from forum members who have recommendations. So please respond with your "helpful" suggestions so I can print this off and show him. Thanks for all your help.
Old Jan 27, 2011 | 09:45 AM
MPlayer's Avatar
MPlayer
I just did the ARP studs on mine. That is the way to go. You could print out threads from here and take them to him. Maybe they will see that is what everyone with a 6.0 does to fix that problem. You may have to pay the difference though for the studs.
Old Jan 27, 2011 | 09:53 AM
bismic's Avatar
bismic
ARP head studs (not bolts) are a good upgrade, but you must also make sure evrything is absolutely flat (heads and block). I would also have the heads magnafluxed to look for cracks. Have you ever seen any excessive boost readings?
Old Jan 27, 2011 | 09:58 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
My dealer did mine for me but I had to buy and take them to him. Yes, they charged me a little more to install them..... a couple of hours I believe.
Old Jan 27, 2011 | 12:35 PM
rdunagan's Avatar
rdunagan
worth every penny to do studs. That is the only perminate fix to the head gaskets leaking. im pretty sure anyone who has common since will use studs. everyone i know that owns a 6.0 has studded it. hope this helps
Old Jan 27, 2011 | 12:36 PM
rdunagan's Avatar
rdunagan
worth every penny!!!!! everyone i know that has a 6.0 has done studs. its the only perminate fix to the head gasket problem. along with a egr delete or billet cooler. hope this helps
Old Jan 27, 2011 | 12:56 PM
John Irwin's Avatar
John Irwin
High cylinder pressure causes the stock "torque to yield" head bolts to stretch and the heads "lift" causing the gaskets to blow out. The studs have a considerably higher clamping force so the heads don't lift. I've been wondering if the weak head bolts don't contribute to the warping problem too by allowing the heads to flex while they're lifting. I'm no expert, just thinking out loud. Remember if you get the heads machined, take only enough off to true the head, and I think 8 thou is the limit.
Old Jan 27, 2011 | 01:25 PM
Paul_Bonner's Avatar
Paul_Bonner
When the head gasket leaked on my 04 6.0L SD - the bolts were replaced with H11 studs. The main issue discovered was that the cylinder head surfaces on the block were roughly machined (milled) and the cylinder pressure was escaping into the water jackets through the furrows in the surface. On mine this was cured by hand-lapping the block until it was properly smooth and flat. Heads were machined at the same time to ensure everything was like new.
Old Jan 27, 2011 | 06:38 PM
cheezit's Avatar
cheezit
as a ford tech ill will say I put them in my truck. not looked back sence. you will need to pay for the studs on your dime and possibly some added labor.
westkane
Jul 1, 2013 05:10 PM
turbill
26
Sep 30, 2010 10:44 AM
buckrogers
Jun 12, 2007 09:01 PM
Burnz
Oct 29, 2003 10:32 PM
