92 F150 4X4 E4OD PROBLEM...PLEASE HELP
Old Jan 27, 2011 | 09:04 AM
cato47's Avatar
cato47
I just bought a 92 F150 4X4 EXT CAB with a 5.0 and the E4OD auto trans with the 4X4 push buttons on the dash. It has one button for regular 4X4 and one button for low range 4X4. Regular 4x4 works great and both of the indicator lights come on. Then, if I push the button to go into 4X4 Low range, neither of the indicator lights come on and I'm thinking it's probably not engaging into low range 4X4. Can some one shed some light on this for me.
Thanks guys and please chime in with any help, please.
Many Thanks,
Rick
Old Jan 27, 2011 | 09:09 AM
fdude64's Avatar
fdude64
how are you trying to shift to low range? straight from 2wd? or from 4hi?
Old Jan 27, 2011 | 09:29 AM
White Max's Avatar
White Max
Are you putting the transmission in neutral before pushing the button for 4 Low?
-Rod
Old Jan 27, 2011 | 09:47 AM
cato47's Avatar
cato47
fdude64:
I have put the E4OD into Hi range and then pushed the button for low range and the lights don't come on. I have also from PARK, gone stright to Low range and the light doesn't come on.
Old Jan 27, 2011 | 09:50 AM
cato47's Avatar
cato47
To: White Max
I am not putting the transmission in neutral before pushing the button for 4X4 low.
Old Jan 27, 2011 | 09:54 AM
White Max's Avatar
White Max
Originally Posted by cato47
To: White Max
Give that a try. If that doesn't work, I'd bet that the problem lies in either the switch or the actuator on the transfer case.
-Rod
Old Jan 27, 2011 | 10:55 AM
cato47's Avatar
cato47
White Max:
I'll give your suggestion a try. By any chance have you ever taken the dash cluster (instrument panel) out of this vintage truck. If so how do you do it?
Thanks,
Rick
mrsandog
Dec 3, 2009 12:45 PM
Biggiebronco92
1978 - 1996 Big Bronco
Nov 25, 2009 10:50 AM
fordtruckboyf150
Sep 5, 2007 08:15 PM
vols_fan22
Apr 3, 2007 04:27 PM
marragtop
Dec 27, 2002 10:32 PM
