1978 - 1996 Big Bronco
4x4 Low Range problems
Old Nov 18, 2009 | 08:57 PM
Biggiebronco92's Avatar
Biggiebronco92
Hey guys, I am having problems with my 4x4L
my 2wd, and 4high works great but when i press the button to get low range after pressing 4x4 nothing happens,....
my setup..
e4od
mile marker maual hubs
push button
WHAT to DO?
Old Nov 18, 2009 | 10:45 PM
Conanski's Avatar
Conanski
Originally Posted by Biggiebronco92
WHAT to DO?
You have to be stoped with the transmission in neutral to select 4L.
Old Nov 19, 2009 | 10:39 AM
Kemicalburns's Avatar
Kemicalburns
manual tcase swap
Old Nov 19, 2009 | 06:49 PM
Biggiebronco92
i know its gotta be in neutral not moving...
and im not spending any $, i just wanna figure out why my system isnt working right now in 4L....
Old Nov 19, 2009 | 07:28 PM
g_k50's Avatar
g_k50
Is the t-case motor working? Is the switch broken? Check for voltage at the t-case motor connection when the switch is operating.
Old Nov 24, 2009 | 11:52 AM
Biggiebronco92
its just 4L thats not working so i doubt its the switch...
last time i took it out of 4L (when it worked) it didnt really wanna disengage...then i just went forward n backwereds a few times and she came right on out.
i really need 4L... 37's ))
help pls....
Old Nov 24, 2009 | 03:33 PM
Kemicalburns
pull the motor apart and confirm it works when power is applied to it. if not then replace. Have you made sure the tcase is full of fluid? when you put it in 4l do you hear anything at all?
Old Nov 24, 2009 | 08:27 PM
Biggiebronco92
it has fluid, and theres no noise, like theres not even an attempt from the tcase to put it in 4L....
but 4hi works
Old Nov 25, 2009 | 10:50 AM
Kemicalburns
then honestly i would start with the switch first. i wouldnt try to over complicate things.
JClarkHarris
Oct 19, 2015 12:55 PM
smittys5xs
Mar 27, 2013 07:48 PM
texaskid22
Dec 28, 2012 03:03 AM
vols_fan22
Apr 3, 2007 04:27 PM
PressureDrop
Apr 2, 2005 08:20 PM
