Sponsored by: Real Truck
oil leak?
Old Jan 27, 2011 | 08:45 AM
SANTAALAN's Avatar
SANTAALAN
oil leak?
I have a 1999 7.3 PSD, that is leaking oil from the front bottom. I located on the ft of the motor, a piece of alum tubing bent downward that is open and oil is coming from there leaking on the positive battery cable. What's going on? No oil is found on top or back on engine.
thanks
Old Jan 27, 2011 | 09:45 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
The fluid is diesel coming from the fuel bowl drain valve. Follow the tub and see if it goes to the back of the fuel bowl. Here is how to fix this leak. Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
If you come down to the 7.3 forum, you can find lots of good info on the 7.3.
Old Jan 27, 2011 | 11:10 AM
SANTAALAN's Avatar
SANTAALAN
thanks
Thanks for the info> i will check it all out this weekend.
Santa Alan
Old Jan 27, 2011 | 11:33 AM
Kajtek1's Avatar
Kajtek1
Get a shop vac and clean the valley from diesel and rats droppings. Don't forget to prime fuel after the job.
Old Jan 27, 2011 | 03:40 PM
REXHOUND's Avatar
REXHOUND
yup i concur
ryansmo
Feb 26, 2008 10:55 PM
oem78
Oct 11, 2005 09:33 PM
ford390gashog
Nov 20, 2004 10:35 PM
MJW
Mar 15, 2004 03:05 PM
redygo
Feb 12, 2004 08:39 PM
