should throw a code...and I am certainly no expert...by a long shot. But rough running and more regens leads me to beleive an overfueling condition or a sensor issue.
Just a sensor issue would mean no rough running though.
Just sent another regeneration I check the oil It's pretty high I put the injector cleaner In the truck I'm about 150 miles Away from my dealer I guess we'll see what happens Thanks for your help
Yes I got word around 5pm last night. They are saying the problem is a broken rocker arm. He proceeded to tell me about how poorly made they are and how he see them break more than they should.
Apparently It's a easy fix for them. And it should be covered under the extended warranty. They told me They are constantly Getting issues like this Because there is A little plastic piece in there that is not Designed well and tends to break often
