PO470
Old Feb 23, 2011 | 09:32 AM
Jasonszion's Avatar
Jasonszion
Originally Posted by npccpartsman
Doesn't require much to unplug and screw out the EBP sensor. I use a small crescent wrench. No instructions--it's very straight forward.
ok good deal! thanks guys! Is it hard to get the tube off and clean it as well? I just dont want to tear anything up...
Would you guys try just cleaning the sensor and tube first and then if necessary go back and replace the sensor?
btw I had my EGR cooler and Oil cooler replace about 10k ago... I think I may go ahead and pull the valve and give it a good cleaning...
Old Feb 23, 2011 | 10:02 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Definitely. Just follow the tube down to the front of the exhaust manifold and disconnect it. It'll be a little easier to get at if you take the air filter housing out of the way.
Old Feb 23, 2011 | 11:26 AM
Jasonszion's Avatar
Jasonszion
Ok good deal! I will hit that first thing tomorrow... It has started that surging crap at 40-50 mph... Do you think that is the problem?
tdots410
May 1, 2016 04:43 PM
fordboy300
19
Apr 24, 2016 09:18 PM
Edwardw
Nov 30, 2013 11:47 AM
pbgsho2
13
Jun 18, 2011 01:11 PM
Johnis
Nov 5, 2009 10:52 AM
