Engine Compatibility
Old Jan 26, 2011 | 04:03 PM
Gans's Avatar
Gans
I have an engine knock and am looking at replacing my engine or rebuilding it, whichever is cheaper. I have had a couple of master mechanics look and listen to my engine and they said rebuild or replace. I have a 1990 F250 with a 351 Windsor. I have found a 1990 E150 with a 351 Windsor short block. I would like to know if these engines are interchangeable without any sort of modification. I can do just about any work that has to be done to my truck, but I don't have any knowledge about engines. I would like to do an engine swap but if there would end up being a lot of hassle with swapping these engines I'll just do a rebuild. I would like to thank anyone that takes the time to read this or offers up any information in advance, any information is better than having nothing.
Old Jan 26, 2011 | 05:11 PM
taisa899's Avatar
taisa899
you're good to go
Old Jan 26, 2011 | 07:58 PM
Gans's Avatar
Gans
What is the difference between the two engines? I figured that since it was a Windsor "Short Block" that it was shorter or something. I asked a couple friends that know more on the subject but they couldn't tell me.
Old Jan 26, 2011 | 08:37 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Only difference between van engines vs. truck engines is a longer dipstick tube, and different air intake systems.
You can swap a van engine into a truck without any mods, but you can't put a truck engine in a van without changing some stuff.
So your good to go!
If I remember correctly, short block is a engine without exceseries, and a long block is complete ready to drop in and run engine.
So on that "short block" 351, you'll need all your exceseries off your old 351 to put on that new one. (Alt, Fan, P/S pump, belts, etc.)
Old Jan 26, 2011 | 09:31 PM
Conanski's Avatar
Conanski
Shortblock is just the block and rotating assembly, Longblock is that plus heads. What you need for an easy swap is a complete running EFI 5.8 engine and it doesn't matter what late model truck it comes from they are all compatable with your truck, just be sure to use the accessory brackets and wiring from yours and none of that from the donor.
JMyers0901
May 9, 2014 09:01 AM
Oxfordrider
Oct 13, 2013 12:54 PM
shredder1223
Apr 25, 2008 06:15 PM
fordzilla351
23
Feb 13, 2008 07:33 AM
megapicker
Nov 13, 2003 01:10 AM
