1978 - 1996 Big Bronco
Help Again code 42
Old Mar 9, 2003 | 09:36 AM
icanfixthat's Avatar
icanfixthat
Exclamation Help Again code 42
Hello
Its me needing help again. Im getting a code 42 with engine running, The book is telling me that it is running rich how can I correct this I all ready change the O2 sensor.
Thanks once again
Old Mar 9, 2003 | 12:13 PM
steve83's Avatar
steve83
Help Again code 42
The oxygen sensor doesn't make the engine run rich - it just tells the computer IF it happens. Changing it will rarely fix that code, and then, only if the code was erroneous from the sensor being bad. If the tailpipe isn't turning black with soot, it's probably not running rich.
A rich condition can be cause by blowby (worn rings), leaking injector(s), leaking fuel pressure regulator, bad MAP, bad MAF, wrong timing, bad plugs, bad wires, bad cap/rotor, bad ignition module, weak coil, bad ECT, bad ACT, bad PCV, or probably some other things. Start checking them according to the Haynes manual and you'll probably find the problem.
Old Mar 9, 2003 | 12:32 PM
icanfixthat
Help Again code 42
OK
Ill get started
Thanks
Old Mar 9, 2003 | 12:55 PM
icanfixthat
Help Again code 42
OK
Ill get started
Thanks
Old Mar 10, 2003 | 06:03 PM
icanfixthat
Help Again code 42
Hey Steve83
What is MAF , ECT , and ACT
Thanks
Old Mar 10, 2003 | 08:51 PM
steve83's Avatar
steve83
Help Again code 42
The Haynes manual shows the full names of all the sensors, but those are Mass AirFlow, Engine Coolant Temperature, and Air Charge Temperature.
Old Mar 10, 2003 | 08:53 PM
icanfixthat
Help Again code 42
Thanks Again
Old Mar 11, 2003 | 12:27 AM
dblue351's Avatar
dblue351
Help Again code 42
I love this page!
Code page
