Stroking a 302
Old Mar 10, 2003 | 07:46 PM
ferguson777's Avatar
ferguson777
Stroking a 302
My learned collegues - Is not the 351C a high rpm HP motor whereas the 351W is a lower rev. torque motor? And it's more torque than HP that the average truck wants.
Except for Rage. with 8,000 HP you gets lotsa torque as a byproduct.
Old Mar 10, 2003 | 08:06 PM
fatfenders's Avatar
fatfenders
Stroking a 302
"My learned collegues............."
Hey RMF, I kind of like the way that sounded. Do we get a consulting fee?
Typically more stroke = more torque. Short stroke = throttle response/very rapid RPM build. Not that I am really answering your question. With the wide availability of cams and cylinder heads, you could make either engine any flavor you want. I know the 351W will make huge torque on a budget. I've seen a zillion magazine build ups on it.
'rage couldn't decide whether he wants torque or HP so he decided to just have 8,000 of each to be safe.
Old Mar 10, 2003 | 08:44 PM
bhabben's Avatar
bhabben
Stroking a 302
Daryl,
Don't plan on using your 302 heads, unless you're holding out on us that you've already got a set of higher flowing heads. First, 302's use 7/16" head bolts, 351w's are 1/2". If you have the stock size valves and ports, these may be smaller than what you want. Here's a quick list of valve sizes in some common heads, not to mention the ports and, most importantly, flow velocity and capacity:
1.78"intake/1.45"exhaust; 289, early 302
1.78"intake/1.46"exhaust; 302, 75-up 351w
1.84"intake/1.54"exhaust; 69-74 351w
1.94"intake/1.60"exhaust; common aftermarket valve set used in SBF heads
For comparison you should set a pair of Windsor heads next to a set of Clevelands:
2.04"intake/1.654"exhaust; 351c2v, 351m,400
2.19"intake/1.709"exhaust; 351c4v
2.19"intake/1.710"exhaust; Boss 302, Boss 351
Valve sizes are not everything, and these are 30 year old technology, but this should clue you in to the vast differences available. Before you spend a dime reconditioning and porting a set of used heads, get an accurate total estimate and compare it to what you can buy a complete new aftermarket set from Summit, Jegs,etc.
The Carter AFB and Edelbrock Performer Series carbs are identical. Federal Mogul acquired Carter and rights to the AFB. Edelbrock licenced the AFB from Federal Mogul. Magnetti-Marelli manufactures the carbs for both Carter and Edelbrock . The 500cfm and 625cfm models have identically sized primaries. The 750 has much larger primaries. The Performer 351 kit uses the 625cfm. The Performer RPM 351 kit is designed for the 750cfm.
You can sell your 302 complete and recoup some of your money if you don't canabalize it.
The dealbreaker on most cleveland swaps has been a limited selection of headers that will work in a given chassis. Maybe someone here can enlighten us what will work in an effie.
Adios,
Brett
Old Mar 10, 2003 | 08:55 PM
Caddy 53's Avatar
Caddy 53
Stroking a 302
Daryl: Since you hit the lottery and have a boat load of money, I'm gona have a '72 351 w along w/ fmx to sell as soon as I get it out of truck. It came w /truck and no wiring or etc. so I don't know much about it.Former owner said it ran fine. I would think maybe freshen it up first.But heck you are to far away from me.
I'm going another route on eng & tran.
Anyway my opionwould be to go 351w nothing else.
caddy 53 chuck
Old Mar 11, 2003 | 08:39 AM
DS02F250's Avatar
DS02F250
Exclamation Stroking a 302
All,
I don't have "a boatload of money", but I do work an average of anywhere between 60-100 hours of overtime a month! On good months, it affords me the opportunity to progress on my project truck
For now, I'll focus on the IFS and getting the interior/upholstery/stereo/alarm done. I'll keep the info and responses here for future reference. Thanks to everyone for the input and help...
Daryl
Old Mar 12, 2003 | 02:54 PM
Caddy 53's Avatar
Caddy 53
Stroking a 302
Daryl; This overtime is ok ,I've done my share. Just a thought, Don't burn your candle at both ends.It willcatch up with you. I"ve been tere done that.NOT WORTH IT ON YOUR HEALTH AND PERSONAL LIFE.
Any way have good day.
chuck caddy 53
Old Mar 12, 2003 | 09:19 PM
DS02F250's Avatar
DS02F250
Stroking a 302
Caddy,
You're right; sometimes I try to do too much. Gotta stick to one project at a time. Thanks for looking out for me when I forget to...
Daryl
MonsterTruck\m/
Nov 21, 2011 03:46 PM
410
Dec 17, 2009 02:41 PM
Lee250
21
Jun 26, 2007 02:18 AM
NealLittle
41
Mar 2, 2005 12:16 PM
