I got the SHAKES!
Old 01-25-2011, 06:17 PM
SMITHSTP's Avatar
SMITHSTP
SMITHSTP is offline
I got the SHAKES!
I have a '79 F-150 4x4 with a 351m, NP205 and a C6, my truck has been shaking and vibrating at various speeds. It shakes bad from 0-20mph, then not so bad from 20-40, then stops after 40 when my foot is on the gas but then shakes bad when I let off. I put in new plugs, wires, cap and rotor, compression test was anywhere from 118-130psi. I tried two different drive shafts (u-joints are good), engine and tranny mounts seem ok (not moving around or missing bolts). Timing set to 14°BDC on the marks so I don't think it's the balancer. The tires are old but when I put it in neutral it gets less noticable, just put new ball joints, tie rods, and wheel bearings. I have a clicking sound coming from the bell housing, so at this point I'm thinking maybe the torque converter? Can a torque converter shake the entire truck? FTE is about the best thing ever and I can't wait to see what everyone comes up with. Thanks!
Matt
Old 01-25-2011, 07:08 PM
351coupe's Avatar
351coupe
351coupe is offline
If its a semi-violent to violent shake....its most likely the track bar bracket/bushing.Its very common for those to wear and cause a BAD shake.
The easiest way to check is to have someone rock the steering wheel back and forth,while you look at where the track bar and bracket bolt up.There will be noticeable slop if thats the cause.In some cases you can rock the wheel back and forth yourself and notice the whole nose sway side to side.
If thats not it...Id look into the radius arm bushings next---but my money is on the track bar bushing.Good luck!
Old 01-25-2011, 08:05 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Sounds to me like you have it narrowed down to a "high frequency" engine or driveline vibration. Narrow it farther by kicking it out of gear and reving the engine and see if the vibration is there. If it is the torque converter it should show up. And yes, a torque converter or flywheel will cause vibrations.
Old 01-25-2011, 08:07 PM
skidoodave's Avatar
skidoodave
skidoodave is offline
What size tires are you running? Could be the steering damper is pooched. Check the drivers side frame just on the front side of the steering box for the famous frame crack.
Old 01-25-2011, 09:03 PM
thekingofcows's Avatar
thekingofcows
thekingofcows is offline
Could be a loose rear transfer case bearing.
Old 01-25-2011, 09:59 PM
clhart426's Avatar
clhart426
clhart426 is offline
you mean other people have had the crack in the frame on the front side of the gear box?! i didnt even know mine was until i was installing my lift, and had to take off the front shock tower, and behind that was actually a couple cracks. put a dent in my estimated finishing time having to repair the frame, but, im GLAD i caught it.
my truck vibrates too, but only when giving it the skinny pedal treatment. i'm letting it go til it gets unbearable ha
Old 01-26-2011, 08:25 AM
SMITHSTP's Avatar
SMITHSTP
SMITHSTP is offline
Thanks for the input, I think is is definetly think it's in the "high frequency vibration" category. Already fixed the cracked frame LOL!!! and probably need to look at the track bar bushings so I can keep it safe on the road. Raytasch, when I kick it out of gear it still has the vibration, I'm trying to isolate it to either the engine of tranny at this point. The engine hardly vibrates when it's idleing, I would think if the vibration was coming from the engine I could at least see it. When I put it in drive put my foot on the brake and hit the gas it feels like the truck is going to shake apart!
Old 01-26-2011, 09:43 AM
704 dentside man's Avatar
704 dentside man
704 dentside man is offline
Before I went tearing in to the TC, I'd have a real good look-see at the front end, and make sure everything is greased and in good working order...remember, a couple little problems can culminate to one big problem. I've had shock towers come loose that caused vibrations...and I think an extremely overlooked part is the axleshaft u-joint.
That said, checking that stuff is free, and I figured could be ruled out...but it does sound like a potential TC issue to me.
Strokerboy73
27
11-16-2015 07:38 AM
VTENX
05-28-2015 03:33 PM
mjp74
1999 to 2016 Super Duty
30
04-28-2015 10:29 AM
powerstroker100
86
11-23-2014 10:53 PM
Truck Guy99
05-27-2014 01:14 PM
Quick Reply: I got the SHAKES!
