97 f350 trans problem
Old Jan 25, 2011 | 11:14 AM
brianderby's Avatar
brianderby
I have a 97 f350 powerstroke with e40d trans problem I am having is it shifts in out of high gear.there is no codes no check engine light and it shifts fine with no banging or overdrive light flashing.speedometer works fine,fluid is not burnt,just downshifts like your mashing into it to pass any ideas???
Old Jan 25, 2011 | 08:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be the Transmission Range Sensor (TRS,) also known as the Manual Lever Position Sensor (MLPS.) When it starts to fail it will cause the trans to downshift at random times. It won't set a code or flash the OD light. It is the sensor on the driver's side of the trans where the shift cable attaches.
Old Jan 26, 2011 | 03:09 PM
brianderby's Avatar
brianderby
Mark, thank you, went to sensor it was so corroded with road grim i dont know how it even worked at all ,working great now
