Idle air control question
Old Jan 24, 2011 | 10:14 PM
95F150Guy's Avatar
95F150Guy
I have a 95' 5.8l F150, what other year F150's or other engines used the same IAC? I need a new one and don't want to pay the Dealer price
Old Jan 24, 2011 | 10:38 PM
DBGrif91's Avatar
DBGrif91
I don't know what a dealer is asking but I bought a brand new one [not sure of the brand] from O'Reilly for about $60 for my 91 5.8.
Old Jan 25, 2011 | 10:12 AM
95F150Guy's Avatar
95F150Guy
can you check to see what the brand was?
Old Jan 25, 2011 | 10:14 AM
Conanski's Avatar
Conanski
All '87-96 E and F series 5.0 and 5.8 motors use the same IAC valve, and there is good potential most other engines from this era do as well.
Old Jan 25, 2011 | 10:21 AM
DBGrif91's Avatar
DBGrif91
Mine was a Master Pro one year warranty. And sorry I was off on the cost a little- their website is showing it for $66.99 right now.
Have you considered going to the local junk yard? I know it can be a crap shoot as far as part quality but if you're money is tight then that would be the next most reasonable option.
Old Jan 25, 2011 | 11:02 AM
73FOMO's Avatar
73FOMO
Rock Auto has them ranging from $24.99 up to $101. You may want to check them out, but I agree with Conanski that the same IAC is used on a bunch of different vehicles from these model years.
Old Jan 25, 2011 | 11:23 AM
woodys ride's Avatar
woodys ride
89 f 250
i have an 89 f 250 i put a new iac valve in it and it still will not idle when it is cold could someone help me out with this problem please
Old Jan 25, 2011 | 11:30 AM
timbersteel's Avatar
timbersteel
Just got one from the the dealer for my 302, $84. I know that my 302 and 300 are closely identical except for the position of the electrical connector.
Both are '92's.
Edit: Woodys ride, I would check for frail, brittle vac. lines, may even have one broken. You may want to start with checking the throttle body for gunk buildup. Many other checks include, plugs, wires, even carbon on the contacts inside of the cap of the dizzy and the rotor itself.
Idle problems are usually associated with the vac. problems. But would check the butterflies in the throttlebody. Have you also checked for codes? The CEL doesn't necessarily need to be lit to indicate a problem.
Old Jan 25, 2011 | 11:39 AM
73FOMO's Avatar
73FOMO
Also, may want to check your ECT sensor. It has alot to do with fuel at cold temps.
Old Jan 25, 2011 | 12:03 PM
woodys ride
well every thing has been cleaned in the throttle body couse i took it apart to put a throttle positioning sensor in it. and ive done a tune up on it and it is not trowing any codes so ive looked for vacum leaks before and never found anything
Old Jan 25, 2011 | 07:33 PM
95F150Guy's Avatar
95F150Guy
Yup, considered the junk yard, thats why I asked what year/engines used the same IAC
Old Jan 26, 2011 | 08:25 AM
Hunt89's Avatar
Hunt89
I have a 89 f150 with a 4.9. I know the iac is diffrent but I had some brand from O'Reillys and it was not very reliable. I bought a motorcraft and my truck runs like a champ now. Motorcraft is a little more but it is worth it. I got mine off of amazon.com and it was like $70 or $80.
Old Jan 26, 2011 | 08:38 PM
95F150Guy's Avatar
95F150Guy
+ 1 on using a more reliable part(motorcraft), for something like this, I would pay a little more too. If I can't find a good used one, I'll look for the cheapest(price) OEM. Kind of hard to surf junk yards this time of year in northern Wisconsin! Too much snow!
TwoF150
Jun 7, 2015 04:11 PM
Walwal44
Oct 20, 2014 03:32 PM
Lebowskii
Aug 31, 2011 02:17 AM
bjoern
Nov 27, 2000 06:52 PM
