01 F-350 missing
Old Jan 23, 2011 | 06:53 PM
cowboy4x4's Avatar
cowboy4x4
01 F-350 missing
I have a 2001 F-350 7.3, the truck is running rough and this started after the last fill up and its very cold here right now. I pulled the codes and I came up with:
P0603- Internal Control Module Kam error
P1316-Injector circuit/ IDM codes detected
What do these mean, and how do I go about resolving the issues? please be easy on me im a little new to diesel land lol.
Old Jan 23, 2011 | 07:34 PM
Fully_Loaded's Avatar
Fully_Loaded
Where are you located?? There may be someone on here that is real close to you as well if you do not figure it out.
Old Jan 23, 2011 | 07:46 PM
F350-6's Avatar
F350-6
More than likely you've got a loose UVCH. How rough is it running? Just a miss or shaking like it's about to fall apart?
Old Jan 23, 2011 | 07:56 PM
cowboy4x4's Avatar
cowboy4x4
What is a UVCH?
just a miss, and it feels very powerless. Im in sudbury Ontario if anyones available. I have a heated shop and all the goodies at my disposal.
Old Jan 23, 2011 | 07:58 PM
megawatt00's Avatar
megawatt00
UVCH is the Under valve Wiring Harness
Is it possible that you bought some bad fuel?
Old Jan 23, 2011 | 07:59 PM
bulla's Avatar
bulla
Under valve cover harness.
Old Jan 23, 2011 | 08:02 PM
cowboy4x4's Avatar
cowboy4x4
yes I do believe fuels the issue but i want to know why im getting these codes also. I buy my fuel at a small shop with above ground tanks and have had 0 issues yet but i fueled on thurday afternoon and a friend of mine said he couldnt fuel there thursday night because they were empty so I got the botom of the tank. Im hoping thats the issue, going to pop a new filtr in her tommorow and top of the tank with fresh fuel and more conditioner. These temps probably arent helping either right now its -36.
how do i check the harness?? do i just check the plugs outside the valve covers or is there a connection on the inside that i would need to pull the valve covers off to check??
Last edited by cowboy4x4; Jan 23, 2011 at 08:06 PM. Reason: more info and easier reading
Old Jan 23, 2011 | 08:19 PM
F350-6's Avatar
F350-6
Read this thread. https://www.ford-trucks.com/forums/8...ck-shakes.html
Or at least the first part of it. It has pictures and the testing procedure. Toward the end there's a video on youtube you can watch if you make it that far.
Old Jan 23, 2011 | 08:27 PM
cowboy4x4's Avatar
cowboy4x4
WOW! I love this site!!! Thanks you all for helping me out with this problem, the link you gave me describes my exact issue and explains very detailed on how to check the uvch. I will dig inot her tomorow and hopefull get it all fixed up. I post back on my success.
I really hope this is the problem as my wife is 9 months prego and i need this rig to get her to the hospital.
thanks again for everybodys help
