Custom bumper ideas
Old May 19, 2011 | 10:54 AM
  #46
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Me too,,,,,,
Old Jun 5, 2011 | 11:49 PM
  #47
Josh88Ford's Avatar
Josh88Ford
Its finally on the truck, but still figuring out how I want to wire it.
(https://www.ford-trucks.com/forums/1...lternator.html)
Pictures from phone. The superduty lettering is the same gray as the interior
Old Jun 6, 2011 | 06:06 AM
  #48
SkySkiJason's Avatar
SkySkiJason
That is out-of-control!!! Excellently done.
For wiring I recommend 3way switches (DPDT on-off-on). Wire one side 'hot' so you can turn on lites independently and have the other side of the switch powered from low beam for fogs and high beam for driving lite switch.
Old Jun 6, 2011 | 10:40 AM
  #49
oreocreaming's Avatar
oreocreaming
looks great man, i wish my break could bend that thick of steel! nice one of a kind bumper. planning to start building the same style for my obs after the psd turbo install and the paint
Old Jun 6, 2011 | 03:10 PM
  #50
Josh88Ford's Avatar
Josh88Ford
I have the riffraff f650 dash with switches for both the fog lights, and driving lights(seperate) I am just figuring out how to wire all this to the batteries.
The obs bumpers are easy to make because the grille and lights are parallel with eachother!
Old Jun 6, 2011 | 07:41 PM
  #51
SkySkiJason
Well, I got you covered there too!! Check this out:
These are relays with bases. Get your 12v from the power-side of that big relay on the pass-side fender well. Then, just small wires from 12v to your switches and then to the new relays.
I'll get you a link for those relay bases that snap together...
Old Jun 6, 2011 | 10:54 PM
  #52
Josh88Ford's Avatar
Josh88Ford
The piaa lights already come with a relay for the 6" and a fuse for the 4". I am and going to be running the portable winch. Lights. Gauges. Amp for subs. I will be running knukoncept 3 0ga outlet battery terminals with a distribution block. But i need to redo the bridge cable and run the power and ground cables from the alt to both batteries instead of just the drivers.
Old Oct 8, 2011 | 03:07 AM
  #53
pbudzy's Avatar
pbudzy
Show us your fun wiring when done too please please.
Old Oct 8, 2011 | 10:57 AM
  #54
bearman113's Avatar
bearman113
Alaska Chapter ******
Let me know how much you want for a copy of your design plans, think I could talk a buddy or two into making me one. Thanks
Old Oct 10, 2011 | 06:00 AM
  #55
Josh88Ford's Avatar
Josh88Ford
https://www.ford-trucks.com/forums/1...batteries.html
Old Oct 24, 2011 | 10:48 PM
  #56
Josh88Ford's Avatar
Josh88Ford
Here is the last touch...the Winch
I built the winch cradle, weighing 25 lbs. Powdercoated. I put on another hitch receiver(where the big celevis is) so I can hook up a car trailer, boat trailer ect and not have to worry about the trailer moving.
Powdercoated celevis'(powdercoater said the the gray didnt match the bumper so he had to do it)
Quick connects were wired with 0ga up to a Continous duty solenoid(Warn) and to the battery. With a flip of a switch, I have power going to the bumper.
Everything is holding 13.9 volts, so I must of done something right!
Old Oct 25, 2011 | 04:51 AM
  #57
megawatt00's Avatar
megawatt00
That looks outstanding Josh! Nice job!
Old Jun 10, 2012 | 09:05 AM
  #58
Josh88Ford's Avatar
Josh88Ford
I think I finally have this winch wiring figured out!
I've bought replacement continous duty solenoids directly from Warn that was sapose to be for this winch. After research, I found that solenoid is only rated for 200 amps. At a 9000lb pull, the winch draws approx. 450 amps. I found the biggest Continous duty solenoid on the market fro texasindustries.com 1500 amp, 500 amp continous duty.
winched a few trees out of the lake yesterday and very satisfied with this setup
Old Jun 10, 2012 | 09:39 AM
  #59
Crewcab Turbo's Avatar
Crewcab Turbo
Wow that bumper turned out great!!!! Just an idea for those who can't make the whole thing themselves and cant afford buying a complete one, try searching Road Rhino weld it yourself bumpers. There bumpers are similar and you can buy all the pieces and weld the whole thing yourself or you can buy it tacked together by them and do the rest of the welding yourself, or a complete painted one. A unwelded one is about $500+ or so if I remember correctly. They are in University Park Il. About 1.5 hours away from me.
Old Jun 10, 2012 | 01:54 PM
  #60
firestroker8706's Avatar
firestroker8706
I've been looking for a similar solenoid. I tried going to the texasindustries.com website, but they're a cement company. Can you clarify where you got it from?
