732 TRANNY CODE
Old Jan 23, 2011 | 07:51 AM
THE HOGG's Avatar
THE HOGG
732 TRANNY CODE
TWO DAYS AGO MY TRANSMISSION STOPPED SHIFTING FROM 1ST TO SECOND GEAR ON ITS OWN. NOW I HAVE TO LET OFF OF THE THROTTLE TO GET IT TO SHIFT. MY SPEEDOMETER HAD QUIT WORKING RIGHT A MONTH OR SO AGO BUT I DIDNT THINK MUCH OF IT BECAUSE I USE A GPS SPEEDO ANYWAYS. YESTERDAY I CHANGED THE VSS AND NOW THE SPEEDO WORKS BUT STILL THE SHIFTING PROBLEM. I CHECKED THE CODES AND GOT A 732 CODE. WHAT SHOULD I CHECK NEXT? THE TRANSMISSION ONLY HAS 18,000 MILES ON IT FROM FORD. IS IT TRASH??
Old Jan 23, 2011 | 12:11 PM
TYZ78F150's Avatar
TYZ78F150
Is it P0732? That shows Gear 2 Incorrect Ratio. Coule be related to either the ISS or OSS. Since the tranny only has 18k on it, won't ford warranty it?
Old Jan 23, 2011 | 06:54 PM
THE HOGG's Avatar
THE HOGG
YES SIR, PO732. AND NO, FORD WARRANTIED THE LAST ONE AND SAID THAT SIINCE THE TRUCK WAS LIFTED WITH BIG TIRES THAT THEY WOULD NOT WARRANTY IT.. WHAT IS THE ISS AND OSS?
Old Jan 24, 2011 | 03:00 PM
TYZ78F150's Avatar
TYZ78F150
Input speed sensor
Output speed sensor
crazymut
Dec 16, 2009 11:15 PM
a-rod
Aug 7, 2008 08:52 AM
two9292
Feb 20, 2007 06:30 PM
JPR2300
Nov 20, 2005 12:21 AM
