Code help
Old Dec 16, 2009 | 10:15 PM
crazymut's Avatar
crazymut
Code help
Pulled codes tonight and need some insight.
P1280 ICP out of range
PO603 Internal controll module KAM error
PO781 1-2 shift error
PO 732 gear 2 incorrect ratio
The po781 and po 732 make some sense because my trans is in bad shape right now. But anymore info would be great. Thanks
Old Dec 16, 2009 | 10:22 PM
big poppa's Avatar
big poppa
The po603 is just your computer telling you have a chip in it, I get it all the time, clears easy. Pretty sure the po1280 is caused by your chip too but somebody will correct me if I'm wrong.
Old Dec 16, 2009 | 10:24 PM
crazymut's Avatar
crazymut
Actually my chip is out right now, for about two weeks now. I am sending it in for a reflash for the new trans.
Old Dec 16, 2009 | 10:38 PM
big poppa's Avatar
big poppa
O boy, you got me Terry, even though the chip is out it info might be still logged in your PCM, a not sure now bump..
Old Dec 16, 2009 | 10:48 PM
crazymut's Avatar
crazymut
I would imagine with the wierd throttle usage I have had to use just to get it to shift lately could cause some of this. I just hope I dont have more going on now. I dont know how long the codes have been there. I pulled them a couple of weeks ago when my trans first started acting up and the only thing there was the glow plug codes. Since then my trans has been setting off the flashing overdrive light which explains the tranny codes. I dont know about the others though.
Old Dec 16, 2009 | 11:03 PM
big poppa's Avatar
big poppa
Like I said in my earlier post, maybe those codes stayed in there even after you pulled the chip, the PCM does store codes and I wouldn't think just pulling the chip, those codes would go away until you cleared them, still subscribing though. Terry, I can't wait till your J. Wood tranny thread, lol..
Old Dec 16, 2009 | 11:07 PM
Visseroth's Avatar
Visseroth
Best thing you can do is clear the codes and see which ones come back with the chip out. Then you'll get accurate code readings.
Old Dec 16, 2009 | 11:12 PM
crazymut's Avatar
crazymut
J Woods tranny
I cant wait either. Hopefully on Saturday.
Old Dec 16, 2009 | 11:15 PM
big poppa's Avatar
big poppa
a-rod
Aug 7, 2008 08:52 AM
sparky00
Feb 13, 2008 04:30 PM
sparky00
New Member Introductions
Feb 12, 2008 08:02 PM
