Ecm
Old Jan 27, 2011 | 08:07 PM
  #46
jcahicks's Avatar
jcahicks
Found it just plugged it in. thanks
Old Jan 27, 2011 | 08:08 PM
  #47
zx250's Avatar
zx250
Of the next Riffraff East
Happens all the time. Plug it up for the night and see if she starts in the morning.
Old Jan 27, 2011 | 08:09 PM
  #48
jcahicks's Avatar
jcahicks
Ok thanks alot
Old Jan 27, 2011 | 08:12 PM
  #49
zx250's Avatar
zx250
You might want to go check it after an hour or so. just look the cord over good and make sure all looks good as far as smoke or hot spots. It should be fine, but having never used it, it would pay to check on it.
Old Jan 27, 2011 | 08:20 PM
  #50
BigAlsPSD's Avatar
BigAlsPSD
Glad you found it, happens alot as Barry said, I bet this week I've helped 5 people find them on their trucks, not on the internet either, just around my area. Good luck, I hope it works for you, if it does, it sounds like you might have to look into the injectors, or get access to a scanner or AE in order to find out the cause.
Old Jan 27, 2011 | 08:40 PM
  #51
jcahicks's Avatar
jcahicks
Ok thanks again guys,
Old Jan 28, 2011 | 07:01 PM
  #52
jcahicks's Avatar
jcahicks
Ok left the battery charger on trickle all night came out this morning it said bad battery, So I replaced it with a new one this afternoon. had left the heater plugged in all night and day also, changed the oil in it this afternoon tried starting it seemed like it came closer to starting but wouldnt am charging the other battery now so we will see in a little while . Any other ideas while I wait?
Old Jan 28, 2011 | 07:07 PM
  #53
zx250's Avatar
zx250
Well, most of use change the batteries in pairs. Usually if you have one bad battery, the other is nearly as bad. If one is weak, it will pull down the other and cut the life of it down.
Old Jan 28, 2011 | 07:10 PM
  #54
jcahicks's Avatar
jcahicks
I thought about that but this one is only about 8 months old it should be ok. Or so I think. I have been known to be wrong at least once before.
Old Jan 28, 2011 | 07:12 PM
  #55
zx250's Avatar
zx250
Hopefully, you can always have it load tested to be sure. Did you ever check the voltage while you attempted cranking?
Old Jan 28, 2011 | 07:18 PM
  #56
jcahicks's Avatar
jcahicks
No how do I do that have my wife crank it and hold my test meter where?
Old Jan 28, 2011 | 07:25 PM
  #57
zx250's Avatar
zx250
Hold it on your older battery. black lead on the - and red on the +. Be sure meter is set to 20volt DC. Have her crank while you watch the meter. Shouldn't drop below 11volts. 10.5 is the miminum.
Old Jan 28, 2011 | 07:37 PM
  #58
jcahicks's Avatar
jcahicks
Ok did that it dropped to 10.67 at its lowest it almost started my new battery is 1000 cranking amps and the old one is 850 and my charger said the old one was at 97 percent when I started cranking I wonder if I should go get another battery with 1000 amps or not?
Old Jan 28, 2011 | 07:42 PM
  #59
zx250's Avatar
zx250
10.67 would be just about the bare minimum. Yeah, I think a new battery might be a good idea. If it's that new, it should be warr.
Old Jan 28, 2011 | 08:13 PM
  #60
jcahicks's Avatar
jcahicks
WOOOOOOOOOOOOOOOOOHOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!! !!!!!!!!!!! It started and is still running. THANK YOU ALL SO MUCH FOR ALL YOUR HELP AND ADVICE AND ENCOURAGEMENT. My dad went and bought a charger with a booster on it and it started right up. I think I will go get another battery and then put this small one back in my wifes truck and take the gel cell out of her truck and put it back in my old 71. Thanks again guys Il be back on here tomarrow I gotta go clean up .
